Regular expression help
rs232
Post by rs232 »
I'm trying to use Ant Renamer to remove any character after the year in a folder name.
I'm a bit confused on what's Ant renamer is asking me to do.
I've tried
(.+(?:(?:19|20)[0-9]{2})).(.*)
match everything until the 4 digit year and match everything else afterwards
with new name:
S1
but I get the following error in the preview:
<RegExp Error> TRegEpr(comp): Unrecognised Modifier (pos 14)
Any tip on how to fix please?
Thanks! :-)
Re: Regular expression help
The regex parser that I use is probably somewhat limited
Wouldn't it work also with such basic solution?
(.+)((19|20)[0-9]{2}).(.*)
new name:
$1$2$4
rs232
Post by rs232 »
That worked beautifully.
Thanks!
