[UPD ITA] MyMovies.it - prerelease
mrobama
Post by mrobama »
This is a pre release version. MyMovies uses for some links a https:// url and we are waiting for an Ant Movie Catalog new release for fix https protocol handling.
This new version detect news links in the search results page and use them instead of old ones. But we have to wait the new https support to check if parser works well.
Try this test: search for "battleship" and try the first result (is https, so you will get IOHandler error), then try the second result (http, working).
program MyMoviesIT;
  Stringutils7552;
  UrlBase = 'http://www.mymovies.it';
  UrlRicerca = '&titolo_orig=&regista=&attore=&id_genere=-1&nazione=&clausola1=-1&anno_prod=&clausola2=-1&stelle=-1&id_manif=-1&anno_manif=&disponib=-1&ordinamento=1&submit=Inizia+ricerca+%BB';
  QueryBase = UrlBase + '/database/ricerca/avanzata/?titolo=';
  debug_search = false;                                   // debuga mode on/off su ricerca dischi
  folder = 'f:\prova\';                                       // directory where to save files
  ImagePath = UrlBase + '/filmclub/';
  Apice       = #39;
  NoCommento = '(Riceverai le informazioni pochi giorni prima della messa in onda)';  // commenti inutili  "(la recensione più amata dal pubblico)"
  PiuAmata   = '(la recensione più amata dal pubblico)';
  cStartNumRis = 'nel Titolo. Ho trovato '; // Result Number start Marker
  cEndNumRis = ' film.</h3>';               // Result Number end Marker
  cStartId = 'recensione.asp?id=';   // ID start marker
  EndId = '" title="';              // ID end marker
  cStartNewTitle = '<meta property="og:title" content="';
  cEndNewTitle = '"';
  cStartTitle = 'Titolo originale <em>';             // Title start marker
  cEndTitle = '</em>';              // Title end marker
  cStartTranslTitle = '<h1 style="margin-bottom:3px;">';        // Translated title start marker
  cEndTranslTitle = '</h1>';         // Translated title end marker
  cStartImage2 = '<img src="';       // Image start marker
  cEndImage2 = '"';                  // Image end marker
  cStartDirector = 'Un film di <a href="';      // Director start marker
  cEndDirector = '</a>.';                       // Director end marker
  cStartCategory  = '<a title="Film ';   // Catogory start marker
  cEndCategory = '</a>';            // Category first end marker
  cStartCategory2  = '">';   // Catogory start marker
  cEndCategory2 = '</a>';            // Category second end marker
  cStartDuration = 'durata ';        // Duration start marker
  cEndDuration = ' min.';          // Duration end marker
  cStartYear = '<meta property="og:title" content="';              // Year start marker
  cEndYear = '/>';                 // Year end marker
  cStartYear2  = '(';   // year start marker
  cEndYear2 = ')';            // year second end marker
  cStartDesc = '<div id="recensione">';          // Description start marker
  cEndDesc = '<div style="text-align:right;">';  // Description end marker
  cStartCast = 'Con <a href="';              // Actor start marker
  cEndCast   = '<a title="';
  cEndCast2  = 'Titolo originale <em>';      // Actor end marker
  cStartImage = 'src="http://pad.mymovies.it/filmclub/';
  cEndImage = '"';
  MovieUrl, MovieName, Commento, TranslatedStr, PageStr:  string;
  Startchar, EndChar, UsePage, Addressnext: String;
  cImage, SaveField, TempField, DelField : string;
  PositionCategory, PositionDuration: integer;
  Positioncast: integer;
  idx : integer;
function MyTrim(Value: string):string;
  ExitLoop: Boolean;
  NewField, OldField: String;
  OldLgthValue, NewLgthValue: integer;
    NewField := ' ';
    OldField := #9;
    value := StringReplace(Value, OldField, NewField);
    OldField := #10;
    OldField := #13;
    OldField := '  ';
    Newfield := '&';
    OldField := '&';
    Newfield := 'è';
    OldField := '&egrave;';
    ExitLoop := False;
    OldLgthValue := length(Value);
    HTMLRemoveTags(Value);
    Value := FullTrim(Value);
    OldField := '  ';
    NewField := ' ';
      NewLgthValue := length(Value);
    if  OldLgthValue = NewLgthValue then
        ExitLoop := True
        OldLgthValue := NewLgthValue;
    until ExitLoop;
  Result := Value;
procedure estrae_info;          //2017.10.26 cambio struttura sito: aggiunta pagina intermedia tra la ricerca e le info.
  MovieUrl := textbetween(PageStr, '<!-- webTrekk Espresso -->', '<!-- /webTrekk Espresso -->');
  HTMLRemoveTags(MovieUrl);
  MovieUrl := textbetween(MovieUrl, (' pageHref = ' + Apice), (Apice + ';'));
  PageStr := getPage(MovieUrl);
   if debug_search then
      DumpPage(folder+'comingsoon_page_second.txt', Pagestr);                // debug
// ANALYZE MOVIE DATA PAGE
// IN:  none    OUT: set Ant fields
procedure AnalyzeMoviePage;
  BeginPos, EndPos: integer;
  // Get packed title main page
     DumpPage(folder+'mymovies_page.html', Pagestr);                // debug
  if pos('<!-- webTrekk Espresso -->', PageStr) > 0 then
        estrae_info
  if pos('var_carica_taboola', pageStr) > 0
     then
         nuovo_tipo_pagina
         vecchio_tipo_pagina
//end;
procedure nuovo_tipo_pagina;
  titolo_originale, Trama_e_critica: string;
  init_char, end_char: string;
  TempField := TextBetween(PageStr, cStartNewTitle, cEndNewTitle);
  TempField := MyTrim(TempField);
  SetField(fieldTranslatedTitle, TempField);
  // Original Title field
  titolo_originale := TextBetween(PageStr, 'Titolo originale</td>', '</tr>');
  HTMLRemoveTags(titolo_originale);
  SetField(fieldOriginalTitle, titolo_originale);
  if titolo_originale = '' then
    SetField(fieldOriginalTitle, GetField(fieldTranslatedTitle))
  // Director Field
  TempField := TextBetween(PageStr, '<tr><td valign="top">Regia di</td>', '</tr>');
  HTMLRemovetags(tempfield);
  SetField(fieldDirector, TempField);
  // Actors Field
  TempField := TextBetween(PageStr, '<tr><td valign="top">Attori</td>', '</tr>');
  SetField(fieldActors, TempField);            //attori principali
  // Category Field
  TempField := TextBetween(PageStr, '<tr><td valign="top">Genere</td>', '</tr>');
  SetField(fieldCategory, TempField);
  // Duration field
  TempField := TextBetween(PageStr, '<tr><td valign="top">Durata</td>', '</tr>');
  tempfield := Textbefore(' ', Tempfield, '');
  SetField(fieldLength, TempField);
  // Country field
  TempField := PageStr;
  Tempfield := TextBetween(TempField, '<td valign="top">Produzione</td>', '</tr>') + '</tr>';
//  Tempfield := '<tr> href=' + TextBetween(TempField, 'href=', '</tr>');
  Tempfield := '<tr>' + TextBetween(TempField, 'href=', '</tr>');
//  TempField := MyTrim(TempField);
  tempField := textafter(Tempfield, '>');
  SetField(fieldCountry, TempField);
//  Year
  TempField := Textbetween (tempField, '<td valign="top">Anno</td>', '</tr>');
  SetField(fieldYear, TempField);
  // Get film image
  cImage := TextBetween(PageStr, '<amp-img layout="responsive" class="stonda3" width="230" height="330" src="', '"></amp-img>');
  cImage := StringReplace(cImage, 'https', 'http');
  GetPicture(cImage);
// Description Field
   init_char := '<div class="lectios">';
   end_char  := '<div class="clear10">';
   Trama_e_critica := init_char + TextBetween(PageStr, init_char, end_char) + end_char;
   Trama_e_critica := UTF8decode(Trama_e_critica);
      DumpPage(folder+'comingsoon_trama_e_critica.txt', trama_e_critica);                // debug
   TempField := textBetween(Trama_e_critica, '<p class="corpo">', '</p>');
   TempField := StringReplace(TempField, 'Il film Shadow è disponibile in streaming. Scopri MYmovieslive', '');
   TempField := StringReplace(TempField, 'Questo film è disponibile in versione digitale, scopri il miglior prezzo: TROVASTREAMING', '');
   TempField := Fulltrim(Tempfield);
   SetField(fieldDescription, TempField);
// Comments Field
   init_char := 'class="corpo citazione mm-blocco-news" style="display: table;"';
//   TempField := '<p ' + init_char + textBetween(Trama_e_critica, init_char, end_char) + end_char;
   TempField := '<p ' + textBetween(Trama_e_critica, init_char, end_char);
   SetField(fieldComments, TempField);
// Movie URL field
   SetField(fieldURL, MovieUrl);
procedure vecchio_tipo_pagina;
  TempField := TextBetween(PageStr, cStartTranslTitle, cEndTranslTitle);
  SetField(fieldOriginalTitle, TextBetween(PageStr, cStartTitle, cEndTitle));
  if(GetField(fieldOriginalTitle)='')then
  // Director Field
  TempField := TextBetween(PageStr, cStartDirector, cEndDirector) + cEndDirector;
  TempField := TextBetween(TempField, '>' , cEndDirector);
  // Actors Field
  TempField := CstartCast + TextBetween(PageStr, cStartCast, cEndCast);     // da 'con:'   a Titolo
  Positioncast := pos(cStartCast, PageStr) + length(TempField);
  SaveField := TempField;
  TempField := TextBetween(PageStr, cStartCast, cEndCast2);   // da 'con:'   a Titolo Originale
  if length(tempField) > 0 then
      TempField := '<a href="' + TempField
    TempField := '<a href="' + SaveField;
  DelField  := '<div id="attori_espandi"' + TextBetween(TempField, '<div id="attori_espandi"', '</div>');
  TempField := StringReplace(TempField, DelField, '');
  DelField  := '<div id="attori_comprimi"' + TextBetween(TempField, '<div id="attori_comprimi"', '</div>');
  // Category Field
  TempField := TextBetween(PageStr, cStartCategory, cEndcategory) + cEndcategory;
  TempField := TextBetween(TempField, cStartCategory2, cEndcategory2);
//  TempField := TempField + cEndcategory;
//  TempField := TextBetween(TempField, '">' , cEndcategory);
  // Duration field
  TempField := TextBetween(PageStr, '<td valign="top">Durata</td>', '</tr>');
  StringReplace(tempfield, ' minuti', '');
  // Country field
  if PositionDuration > 0 then
     Delete(TempField, 1, PositionDuration - 1)
        if  Positioncast > 0 then
            Delete(TempField, 1, Positioncast - 1)
            if  PositionCategory > 0 then
                Delete(TempField, 1, PositionCategory - 1);
  Tempfield := TextBetween(TempField, '-', ' <strong>');
  if  pos('Transitional', Tempfield)= 0 then
//  Year
  TempField := Textbetween (tempField, cStartYear, cEndYear);
//  TempField := Textbetween (TempField, '(', ')');
  TempField := TextBetween(TempField, cStartYear2, cEndYear2);
  // Get film image
  cImage := TextBetween(PageStr, cStartImage, cEndImage);
  if cImage = '' then
    cImage := TextBetween(PageStr,cStartImage2, cEndImage2)
    if GetOption('Poster')=1 then
       cImage := ImagePath + StringReplace(cImage, '/imm.jpg', '/locandina.jpg')
       cImage := ImagePath + cImage
  if cImage <> '' then
    GetPicture(cImage);
   TempField := TextBetween(PageStr, cStartDesc, cEndDesc) + cEndDesc;
// Movie URL field
// Commento
//   TempField := Textbetween(PageStr, '<p style="padding-right:3px; margin-top:15px;">', '<a href="http://www.mymovies.it/dizionario/critica');
   TempField := Textbetween(PageStr, '">Rassegna stampa</a>', '</td>') + '</td>';
   TempField := Textbetween(TempField, '<p style="padding-right:3px; margin-top:15px;">', '<a href="http://www.mymovies.it/dizionario/critica');
procedure CalcLgthToDelete;
  StartChar :=  '<div class="linkblu" style="padding:3px;"';
  EndChar   :=  '<div class="linkblu" style="padding:3px;"';
  Positioncast := Length(startChar) + Length(Textbetween(UsePage, StartChar, EndChar));
  if Positioncast  = 0 then
     EndChar := '<a href="http://www.mymovies.it/prossimamente/">';
// da 35mm.it
  TempIdFilm, TempTitle: string;
  TempAuthor, TempYear: string;
  LineToDrop, LineToUse, LineTodelete, LineTxt: string;
  LengthFilm, LgthTitle, LineNr: integer;
  PositionCategory, LgthLineToUse, PositionDuration: integer;
  PageAll, PageLoop: string;
  cFilmYear, CYearId: string;
  NewLinkStart, NewLinkEnd: string;
  StartPos, EndPos: integer;
  NewLinkStartPos, NewLinkEndPos: integer;
  if OneFilm then                                                           // per un solo film trovato è OK
      StartChar := 'http://www.mymovies.it/dizionario/recensione.asp?id=';
      EndChar   := '" title=';
      UsePage  := Textbetween(Pagestr, StartChar, EndChar);
      if length(UsePage) > 0 then
          TempIdFilm := StartChar + Usepage;
          result := TempIdFilm;
      PickTreeAdd('Risultati ricerca per "' + getfield(fieldFilePath) + '":', '');                                               // per più pagine di film
      PageLoop := PageStr;
      StartChar := '<a title="Database MYmovies" href="http://www.mymovies.it/film/"><strong>Film</strong></a>';
//fulvio      EndChar := '<a href="http://www.mymovies.it/database/">Effettua una nuova ricerca</a>';
      NewLinkStart := 'Media:<br />';
      NewLinkEnd := '#trovastreaming">';
      UsePage := TextBetween(PageStr, StartChar, EndChar) + EndChar;
      repeat                     // inizio gestione pagina multipla
        LineNr  := Pos('>Pagina successiva', PageStr);
        PageAll := UsePage;
        Positioncast := Pos(StartChar, UsePage);
        Delete(UsePage, 1, Positioncast - 1)
        CalcLgthToDelete;
          CalcLgthToDelete;
          EndChar   :=  '<div class="linkverde">';
          LineToUse := StartChar + textbetween(UsePage, StartChar, EndChar) + EndChar;
          StartChar := '<div class="linkverde">';
          LineToDrop := textbetween(UsePage, StartChar, EndChar);
          if Length(LineToDrop) = 0 then
          LineToDelete := LineToUse + LineToDrop;
          PositionDuration := Length(LineToDelete);
          StartPos := pos(StartChar, UsePage);
          EndChar := '" title="';
          if StartPos > 0 then
              TempIdFilm := StartChar + TextBetween(UsePage, Startchar, EndChar);
              // fixed new urls: 13/03/2018
              NewLinkStartPos := pos(NewLinkStart, LineToUse);
              if NewLinkStartPos <> 0 then
                  NewLinkEndPos := pos(NewLinkEnd, LineToUse);
                  if NewLinkEndPos > NewLinkStartPos then
                      TempIdFilm := TextBetween(LineToUse, NewLinkStart, NewLinkEnd) + NewLinkEnd;
                      TempIdFilm := 'https:' + TextBetween(TempIdFilm, '"http:', NewLinkEnd);
              LengthFilm := length(StartChar) + length(TempIdFilm);
              Delete(UsePage, 1, LengthFilm);
              StartChar := 'title="';
              EndChar := '">';
              TempTitle := TextBetween(UsePage, Startchar, EndChar);
              LgthTitle := Length(TempTitle) + length(StartChar) + length(EndChar);
              TempTitle := FullTrim(TempTitle);
              LgthTitle := length(StartChar) + LgthTitle + length(EndChar);
              TempAuthor := Textbetween (UsePage, 'Un film di <b>', '</b>');
              TempAuthor := Textbetween (TempAuthor, '">', '</a>');
              TempYear   := Textbetween (UsePage, '<a href="http://www.mymovies.it/film/?anno=', '">');
              TempTitle  := TempTitle + ' (' + TempAuthor + ') ' + TempYear;
              PickTreeAdd(TempTitle, TempIdFilm);
             Delete(PageAll, 1, Positioncast - 1);
             UsePage := PageAll;
        until(Positioncast < 100);
        result := '';
// Controlla se ci sono altre pagine di risultati
        StartPos := Pos('Ricerca MYmovies', PageLoop);
        Delete(PageLoop, 1, StartPos - 1);
        StartChar := '<a href="?titolo=';
        EndChar := '">Pagina successiva';
        LineTxt := TextBetween(PageLoop, StartChar, EndChar);
           if Length(LineTxt) > 1 then
              AddressNext := QueryBase + LineTxt;
              LineTxt := LineTxt + EndChar;
          LineTxt := TextBetween(LineTxt, StartChar, EndChar);
        until length(LineTxt) < length(EndChar);
        SetField(fieldcomments, AddressNext);
        Pagestr  := GetPage(Addressnext);
      until (LineNr < 1); // repeat
// IN:  page Url (string)
// OUT: none
procedure AnalyzeSearchPage(Url: string);
  NumRisultati : string;
  PageStr := getpage(Url);
//  SetField(fieldURL, URL);
  NumRisultati := Textbetween(PageStr, cStartNumRis, cEndNumRis);
  if ( (NumRisultati = '0') or (NumRisultati = '')) then
      ShowMessage('Title not found / Nessun film trovato.');
  if NumRisultati = '1' then
    MovieUrl := PopulatePickTree(true)
      PopulatePickTree(false);
  AnalyzeMoviePage;
  if (CheckVersion(4,2,1)) and (StringUtils1_Version > 5) then
      TranslatedStr := StringReplace(GetField(fieldTranslatedTitle), '.', ' ');
      if (TranslatedStr <> '') then
        MovieName := TranslatedStr;
      if(Input('MyMovies.It', 'Enter the title of the movie', MovieName)) then
          MovieUrl := QueryBase + StringReplace(MovieName,' ','+') + UrlRicerca;
          AnalyzeSearchPage(MovieUrl);
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 4.2.1) and StringUtils1 version 6');
Re: [UPD ITA] MyMovies.it - prerelease
mrobama wrote: 2018-03-13 12:20:50 Try this test: search for "battleship" and try the first result (is https, so you will get IOHandler error), then try the second result (http, working).
:??: the problem of too-recent TLS version should give an error about SSL, not the IOHandler error (which happens when trying to access a HTTPS site via a HTTP address)
Grazie Mrobama, ottimi lavori.
Potresti evidenziare nella lista che si ottiene dalla ricerca ante titolo del film gli "http" o "https" ?
:ha:
mrobama
Post by mrobama »
@antp: sorry, you are right, the error message is "Error connecting with SSL".
@fulvio53s03: here the "debug" version with [http(s)] in the result page and a useful ShowMessage before and after opening the movie url. This version is a debug version and only for fulvio53s03 and developers/testers (it doesn't fix the https problem)
Authors=Fulvio53s03  (Original by Claudio Rinaldi & seraphico)
Title=MyMovies
Description=Get movie info from MyMovies.it
Site=www.mymovies.it
Language=IT
Version=2.1
Requires=4.2.1
Comments=
License=
RequiresMovies=1
Poster=1|0|1=Download full-res Poster|0=Download tiny Poster
[Parameters]
program MyMoviesIT;
  Stringutils7552;
  Apice       = #39;
  cEndNewTitle = '"';
  cEndImage = '"';
  idx : integer;
  ExitLoop: Boolean;
    NewField := ' ';
    OldField := #9;
    OldField := #10;
    OldField := #13;
    OldField := '  ';
    Newfield := '&';
    OldField := '&';
    Newfield := 'è';
    ExitLoop := False;
    OldField := '  ';
    NewField := ' ';
        ExitLoop := True
    until ExitLoop;
  Result := Value;
  ShowMessage('Debug IOHandler problem. Getting URL: [' + MovieUrl + ']');
  ShowMessage('Debug IOHandler problem. Done.');
        estrae_info
     then
         nuovo_tipo_pagina
         vecchio_tipo_pagina
//end;
  // Director Field
  // Actors Field
  // Category Field
  // Duration field
  // Country field
//  Year
  // Get film image
  GetPicture(cImage);
// Comments Field
// Movie URL field
  // Director Field
  // Actors Field
  // Category Field
  // Duration field
  // Country field
//  Year
  // Get film image
  if cImage = '' then
    GetPicture(cImage);
// Movie URL field
// Commento
// da 35mm.it
        PageAll := UsePage;
        CalcLgthToDelete;
          CalcLgthToDelete;
              TempTitle := '[http] ';
                      TempTitle := '[https] ';
              EndChar := '">';
              TempTitle := TempTitle + TextBetween(UsePage, Startchar, EndChar);
             UsePage := PageAll;
        result := '';
// OUT: none
  AnalyzeMoviePage;
@mrobama. grazie. Sono molto felice di trovare qualcun altro (italiano) che apprezza questo utilissimo programma.
Scevro da inutili orpelli, semplice, essenziale e completo è il meglio nell'area della catalogazione.
Io lo uso per tutte le mie collezioni di film, musica, libri, software.
:) ;) :grinking:
mrobama
Post by mrobama »
sì, piace molto anche a me :grinking:
Some progress on the SSL/TLS problem, a new version to test:
viewtopic.php?f=6&t=6847
otreux
Post by otreux »
IOHandler error
A me da il solito errore :( Praticamente non mi va più nessuno scritp, non capisco cosa stia succedendo :(
