"Insufficient memory to execute the command"
This is the message of the system only with certain record.
I think that happens when an image is too big to be opened but if i try with the same record and the same image with a fresh system all go right.
Is something i can do to open the bigger images working on registry or other?
All other infos are correctly showed but not the images.
Regards
Lorxx
When does that happen?
When you select a movie in your catalog and it has to display all info + picture?
Maybe there is some incompatibility between some pictures and the program, or the picture is too big, difficult to tell: what size are the pictures that cause problem?
There is no hidden setting for that, so except resizing pictures if it is the case, there is no solution.
alexis1809
Re: Insufficient memory to execute the command
Me pasa exactamente lo mismo pero es porque la base de datos del programa esta muy grande, yo tenia 2500 con sus caratulas en alta resolucion y me empezo a pasar lo mismo, tuve que separar las caratulas en una carpeta adjunta a la base de datos y el problema termino.
