First, I want to thank everyone working on the program and scripts, it is really great and is appreciated!
I have the most recent update and latest IMDB script, but am still seeing a few small problems with the script:
1) It is now only bringing in the first 3 actor's names.
2) For TV shows, it used to bring in the name of the show in double quotes, then the name of the episode. Now it only brings in the episode name.
3) The comments section now always starts out with this text:
"Season 1 Episode 1 All Episodes (62) Next › "
4) If the script is interrupted for any reason, a bad internet connection, whatever, the URL field is changed to "http://imdb.com/title/tt" even if it was correct when the script was started. If it was blank when it started, it leaves the same text, so if you have 'Batch Mode' set to "2", it will fail on the next run. This is the same error as it used to have, it was not caused by anything new.
Thanks,
Greg
IMDB script - still problems
gregp
