Cannot identify file type from header
caboomm
Post by caboomm »
Good morning, I can't open file the .amc file after the computer is locked, I tried to change the AMC version seamlessly.
Can someone help me?
thank you
I suppose it is you who also sent me an e-mail about that?
Just in case, my reply to the e-mail:
This can occur if you try to load a file with an older version than the one which created it.
Or else, it means that the file was corrupted. Normally in the same folder as the .amc file there is a .bak file, corresponding to the previous catalog (before last save), so renaming that one to another name with the .amc extension should give you a readable catalog.
