Using Lookbehind to remove some information at EOF name
wolfkin
Post by wolfkin »
https://regex101.com/r/IgsZfH/3
This is what I have so far.
SampleFileNames:
SampleFileA-[SortCode].xls
SampleFileB-[SortCode][CRCNum].xls
SampleFileC-[SortCode][OtherSortCode][CRCNum].xls
SampleFileD-Date[CRCNum].xls
SampleFileE-Date.xls
In this example I only want to remove [CRCNum] from the file names.
This is as close as I can get. I just don't know how to use lookbehind properly
The RegEx
(?<!\-)\[.+?\](\.\w{3}$)
$1
The Error
<RegExp Error> TRegExpr(Comp): Urecognized Modifier (pos 6)
And finally the ideal outcome
SampleFileB-[SortCode].xls
SampleFileC-[SortCode][OtherSortCode].xls
SampleFileD-Date.xls
What's the "rule" that you try to write?
I do not see the link between your regex and the sample :??:
How could the regex spot the difference between cases A & D ? (i.e. detect what is CRCNum and SortCode)
