DVDEmpire script broken
RayL
Hi, DVDEmpire script 2.2.5 stopped working, tried to update and couldn't. Manually pasted 2.2.6 version in .ifs file, either version gave me the "IOHandler value is not valid". I'm using AMC version 4.2.0.2. Past versions worked, although as DVDEmpire had changed their designs, this isn't the first time the scripts stopped working, however this is the first time an update has not solved the problem. Is someone working on a new script, or have I got something configured wrong that should work? Please help, thank you :-)
Didn't the version 2.2.6 of the script notify you that it needs the version 4.2.1 of AMC ?
"IOHandler value is not valid" is the message that AMC 4.2.0 and earlier are showing when trying to get a page from HTTPS, which they don't support, hence the requirement of version 4.2.1 (since DVDEmpire now uses HTTPS it seems).
With the latest version, the script works for me.
RayL
