allmovie script doesn't work
kalimagdora
Post by kalimagdora »
Please somebody HELP.
My favorit scrip does not work, I am not at all competent, I can not fix it ;)
"IOHandler value is not valid" - That's what it says me :cry:
Thanks in advance
Raoul_Volfoni
All Movie Guide 0.8.3 Update
Post by Raoul_Volfoni »
Here a All Movie Guide 0.8.3 update for testing.
-[Fix] Search
-[Fix] Image
/!\ /!\ Important /!\ /!\
The site being passed in HTTPS protocol, you must change to the 4.2.1 beta version of AMC of 10/08/2015 if you want to continue using the All Movie Guide script.
As the addresses are no longer the same, the batch mode will no longer work. To solve the problem, you will have to change all the addresses of the records by replacing http by https. You can do this easily using the function 'replace a word' of the 'update fields' script by example. (make sure to do a copy of your database before any manipulation on it ... we never know ;))
* No longer necessary with version 0.8.4 ... see below
>>> All Movie Guide (pic).ifs (0.8.3) <<<
kalimagdora
I did everything according to the instructions and the script works again
It's great Big thanks :wink: :grinking:
I updated it on the server then
@raoul > the script could do such replace when processing a movie while working in batch mode, though :) (just an idea for the next time you work on it, in case you have lots of free time)
Raoul_Volfoni
All Movie Guide 0.8.4 Update
antp wrote:@raoul > the script could do such replace when processing a movie while working in batch mode, though smile (just an idea for the next time you work on it, in case you have lots of free time)
indeed ... just wanted to highlight this useful script named 'update fields' ... not because i didn't think about it :p
and for free time, I have as much as you ;) ... but I found a bit to add 3 lines to the code
So here's an update to test.
- [Mod] Automatically changes the address to https if needed in batch mode.
>>> All Movie Guide (pic).ifs 0.8.4 <<<
Strange, I get the same file as with the previous link :??: (though that the link is different)
Raoul_Volfoni
My bad :/ ... the link should work now.
Thanks ;)
Lemaireus
Post by Lemaireus »
Just a word of appreciation: thank you, Raoul, once again, for helping out yet again with an update of this script. Much appreciated.
Lemaireus
Post by Lemaireus »
One little bug: when the script copies 'AMG SYNOPSIS', it leaves out the author's name.
Example: https://www.allmovie.com/movie/more-tha ... ese years.
Lemaireus
Post by Lemaireus »
Example: https://www.allmovie.com/movie/more-than-honey-v570638
The synopsis is taken as:
AMG SYNOPSIS: Filmmaker Markus Imhoof studies the important role of bees in sustaining both organic and industrial concerns, as well as the intricacies of their own behaviors. --
The complete entry should have the author's name at the end as follows:
AMG SYNOPSIS: Filmmaker Markus Imhoof studies the important role of bees in sustaining both organic and industrial concerns, as well as the intricacies of their own behaviors. -- Tracie Cooper
Thank once again Raoul, and Antoine it's good to know that you keep browsing through the forums even after all these years.
Raoul_Volfoni
All Movie Guide 0.8.5 Update
Here a All Movie Guide 0.8.5 update for testing.
-[Fix] Synopsis's author's name
>>> All Movie Guide (pic).ifs 0.8.5 <<<
Lemaireus
Re: All Movie Guide 0.8.5 Update
Post by Lemaireus »
Raoul_Volfoni wrote:Here a All Movie Guide 0.8.5 update for testing.
That's perfect, Raoul, works exactly it should. Thanks a lot for your work!
