[UPD ITA] Filmtv.it aggiornato
piccoli aggiornamenti a Paese e genere.
Little updates to Country and Category.
Authors=Fulvio53s03 (based on Fiezul, PIvello, Valerino & others works).
Title=FilmTV
Site=www.Film.TV.it
Language=IT
Version=3.4.2    29.8.2017
Requires=4.2.0
Comments=
License=
RequiresMovies=1
[Parameters]
program FilmTVIt;
  StringUtils7552;   // Script needs external unit StringUtils7552.pas in scripts folder !
  //Query constants
  UrlBase = 'http://www.film.tv.it';
  QueryBase = UrlBase + '/cerca/?q=';
  QueryFilm = UrlBase + '';
  //Search page constants
  debug_search = false;
  folder = 'f:\';
  Apice       = #39;
  cStartFilmUrl = '<a class="pic" href="'; // ID start marker   //fs2014.04.21
  cEndFilmUrl = '">';                       // ID end marker  //fs2014.04.21
  cStartTitle = '<img alt="';                      // Title start marker  //fs2014.04.21
  cEndTitle = '" src="';                     // Title end marker  //fs2014.04.21
  //Film page constants
  cStartTranslTitle = '<div class="wrap-head">';                  // Translated title start marker
  cEndTranslTitle = '<div class=';                   // Translated title end marker
  cStartOrigTitle = '[<i>';     // Original title start marker
  cEndOrigTitle = '</i>';                   // Original title end marker
  cStartImgLink_ext = '<figure class="locandina">';               // Image start marker
  cStartImgLink_int = '<img src="';               // Image start marker
  cEndImgLink_int = '"';   // Image end marker
  cEndImgLink_ext = '</figure>';   // Image end marker
  cStartListItem = ', ';
  cEndCountry = '<a href="/film/anno';
  cEndListItem = ', ';                           // Generic field marker
  cStartCategory = '/">';                        // Category start marker
  cEndCategory = '</a>';                         // Single Director end marker
  cEndDirectors = '</p>';                        // Directors end marker
  cStartDirector = 'Regia di';                   // Single Director start marker
  cEndDirector = '</p>';                         // Single Director end marker
  cStartCast = 'Con</span>';                     // Cast start marker
  cEndCast = '<strong>';                         // Cast end marker
  cStartActor = '">';                            // Actor start marker
  cEndActor = '</a>';                            // Actor end marker
  cStartDesc = '<h2>Trama</h2>';                 // Description start marker  //FS2012-11-11
  cStartComm = '<blockquote>';                   //fs2013-02-11
  cEndComm = '</blockquote>';                    // Comment end marker
  cStartURL='<li id="sel"><a href="/';
  cEndURL='" title="scheda"';
  InitYear = '<h2>';             //fs2014.04.22
//  EndYear = '</h2>';            //fs2014.04.22
  EndYear = ', con ';            //fs2014.06.03
  searchUrl, MovieUrl, MovieName, OriginalStr, TranslatedStr, File_name, PageStr:  string;
  MoviesFound: integer;
// --------------------------------non più usato post versione 3.3.2 per velocizzare ricerca ------------------
// PAGE PACKING (remove extra spaces, tabs & CR) by Pivello
// IN:  page Url     (string)
// OUT: compact page (string)
function RemoveextraChars(Url: string): string;
  TmpPageStr: string;
  Temp: string;
  PackedPage: string;
  CharPos: Integer;
  n: Integer;
  TmpPageStr := '';
  Page.Text := GetPage(Url);
  for n := 0 to Page.Count - 1 do
    if CharPos = 0 then
    if CharPos <> 0 then
        Temp := copy(PackedPage, 1, CharPos - 1);
  result := PackedPage;
// ANALYZE MOVIE DATA PAGE
// IN:  none
// OUT: set Ant fields
procedure SetMovieFields (htmlStr: string);
  i, h, m: integer;
  CharPos, lungo, posbar: integer;
  Duration, Description, Cast, TempStr, TempImg, hh, mm,temp: string;
  tempDirector, director: string;
  PosParAperta, PosParChiusa: integer;
  imageLink: string;
  sep1, sep2: string;
  SaveHtmlstr, tempvar : string;
  dati_generali, Title_orig, Paese, Anno, Categoria, durata : string;
  // General movie description fields
  anno := '';
  TranslatedStr := TextBetween(htmlStr, cStartTranslTitle, cEndTranslTitle);
  TranslatedStr := TextBetween(TranslatedStr, '<h1>', '</h1>');
  if length(Translatedstr) < 1 then
    TranslatedStr := TextBetween(TranslatedStr, '<h1 >', '</h1>');
  SetField(fieldTranslatedTitle, AnsiMixedCase(AnsiLowerCase(TranslatedStr), ' '));    //Titolo Tradotto
//Dati Generali (tit.orig, paese, anno, genere, durata ecc.)
//  Dati_generali := TextBetween(htmlStr, '<div class="wrap-head-content cf"', '<div class="visione cf">');
  Dati_generali := FullTrim(TextBetween(htmlStr, '<ul class="info cf">', '</ul>'));          //fs2016.09.28
  Title_orig    := TextBetween(Dati_generali, '<li><h2>', '</h2></li>');
  lungo := (length(Title_orig) + 18);
  Title_orig    := FullTrim(TextBetween(Dati_generali, '<li><h2>', '</h2></li>'));
  Title_orig    := AnsiMixedCase(AnsiLowerCase(Title_orig), ' ');
  if  title_orig <> getfield(fieldTranslatedTitle) then
      SetField(fieldOriginalTitle, Title_orig);
//Delete(Line,1,pos('size="2"><a',Line))
  if length(Title_orig) > 0 then          //altri paesi
     Delete(Dati_generali, 1, lungo);
     Paese := TextBetween(Dati_generali, '<li>', '<time>');                //fs2016.09.29
     Anno := TextBetween(Dati_generali, '<time>', '</time>');
     Categoria := fulltrim(Textbetween(Dati_generali, '<span>Genere:</span>', '</li>'));
     durata := fulltrim(Textbetween(Dati_generali, '<span>durata</span>', '</li>'));
     begin                                              //Italia
  HTMLRemoveTags(Paese);
  PosBar := AnsiLastPosEx(',', Paese, true, true);
  if   PosBar > 0 then
       delete(Paese, (posbar), (length(Paese) - PosBar));           //cut old filename
  Paese := Fulltrim(Paese);
  SetField(fieldCountry, Paese);
  SetField(fieldYear, Anno);
  HTMLRemoveTags(Categoria);
  SetField(fieldCategory, Categoria);
  temp := Textbefore(durata, apice, '');
  SetField(fieldLength, temp);
//Get Director
  temp:= TextBetween(htmlstr, cStartDirector,cEndDirector);
  HTMLRemoveTags(temp);
  HTMLDecode(temp);
  temp:= fulltrim(temp);
  setfield(FieldDirector, Temp);
//Get Actors
  temp:= TextBetween(htmlStr, cStartCast,cEndCast);
  HTMLRemoveTags(temp);                       //fs 2012-04-03
  HTMLDecode(temp);
  SetField(fieldActors, FullTrim(temp))
//Get comments
  SaveHtmlstr:= htmlstr;
   if debug_search then
      DumpPage(folder+'FilmTvTrama.txt', SaveHtmlstr);                // debug
  temp:= Textbetween(htmlStr, cStartDesc, cEndDesc);
  HTMLDecode(temp);
  SetField(fieldDescription, FullTrim(temp));
  temp := TextBetween(HtmlStr, cStartComm, cEndComm);
  HTMLDecode(temp);
  SetField(fieldComments, FullTrim(temp));
  htmlstr:= SaveHtmlstr;
  //Get URL
  SetField(fieldURL, movieurl);
  //Get image     http://ftv01.stbm.it/imgbank/GALLERYXL/R201404/the_english_teacher_poster_ita.jpg
  imagelink := TextBetween(htmlStr, cStartImgLink_ext, cEndImgLink_ext);
  imagelink := TextBetween(imagelink, cStartImgLink_int, cEndImgLink_int);
//  setfield(FieldSubTitles, imagelink);
//  if imagelink <> 'http://www.film.tv.it/imgbank/DUMMY/no_locandina.jpg'  then
    if imagelink <> 'http://ftv01.stbm.it/imgbank/DUMMY/no_locandina.jpg'  then
       GetPicture2(imagelink, movieurl);
//     GetPicture(imagelink);
//Returns a text field from an input string strIn (pagestr)
//delIn and delOut: text field delimiters
function getTextDelimited(lIn:string; lOut:string;Var strIn:string): string;
  StartPos: integer;
  len:integer;
  tempStr: string;
  lgth_pagestr: integer;
  lgth_pagestr:= length(strIn);
  StartPos := pos(lIn, strIn);
  if startPos<>0 then
    StartPos:=StartPos+Length(lIn);
    tempStr:= copy(strIn,StartPos,StartPos+length(strIn));
    len := pos(lOut, tempStr);
     if len=0 then
      result:=''
      result := copy(strIn, StartPos, len-1); // get Text Out
  Delete(strIn, 1, StartPos-1 + len-1 + length(lOut)-2);
    result := '';
  HTMLDecode(result);
// IN:  OneFilm flag (bool)
// OUT: one page ID  (string)
procedure PopulatePickTree();
  filmUrl, partialUrl: string;
  filmTitle, filmYear: string;
  StartPos, EndPos: integer;
  Lgth_pagestr: integer;
//      PickTreeAdd('Risultati ricerca per "' + File_name + '":', '');
      PickTreeAdd('Risultati ricerca per "' + getfield(fieldFilePath) + '":', '');
        partialUrl:= getTextDelimited(cStartFilmUrl,cEndFilmUrl,PageStr);
        filmUrl:=UrlBase + partialUrl;
        filmTitle:=getTextDelimited(cStartTitle,cEndTitle,PageStr);
 //fs20160224       filmYear:=getTextDelimited(InitYear, EndYear,PageStr);
        filmYear:=getTextDelimited(InitYear, '</h2>',PageStr);  //fs20160224
//fs20140603        filmYear:= copy(filmYear, 1, 42);
        filmyear := fulltrim(filmyear);              //(FS 2016-02-24
        filmYear:= '   ' + '(' + filmYear + ')';
        filmTitle := filmtitle + ' ' + filmYear;
        filmTitle := Stringreplace(filmtitle, ', con', ',     con');
  HTMLRemoveTags(filmTitle);
  HTMLDecode(filmTitle);
        MoviesFound := MoviesFound + 1;
        if partialUrl<>'' then
          PickTreeAdd(filmTitle, filmUrl);
      until(partialUrl='');
// IN:  html of search page (string)
// OUT: movie url
function analyzePage(htmlSearchPage: string): string;
  FilmId: string;
  result:='';
  if pos('Non ho trovato nulla!', htmlSearchPage) > 0 then
      PopulatePickTree();
      if  MoviesFound > 1 then
          if not PickTreeExec(result) then
                MoviesFound := 0;
      if  MoviesFound <= 1 then
//          begin
//          if not PickTreeExec(result) then
             exit;                    //Select one title
//          end;
// MAIN:
// IN:  none
// OUT: none
  if CheckVersion(4,2,0) then
      if (TranslatedStr <> '') then
        MovieName := TranslatedStr
        MovieName := OriginalStr;
      File_name := MovieName;
      if(Input('Film.TV.It', 'Enter the title of the movie / Inserire titolo del film:', MovieName)) then
          //Get search page
          MoviesFound := 0;
// http://www.filmtv.it/cerca/?q=dalle+9+alle+5+orario+continuato
//          searchUrl := QueryBase + UrlEncode(MovieName);
            searchUrl := QueryBase + Stringreplace(MovieName, ' ', '+');
            searchUrl := AnsiLowerCaseNoAccents(searchurl);       //fs 2016.09.05
//FS 2016.02.24                    PageStr := RemoveextraChars(searchUrl);
          Pagestr := GetPage(searchUrl);      //FS 2016.02.24
          PageStr := UTF8Decode(PageStr);
          //Analyze search page and get movie url (user choice)
          MovieUrl:=analyzePage(PageStr);
          // Get movie page
          if  MoviesFound = 0 then
//FS 2016.02.24          PageStr := RemoveextraChars(MovieUrl);
          Pagestr := GetPage(MovieUrl);      //FS 2016.02.24
          Pagestr := Stringreplace(Pagestr, '’', '´');
          //Analyze movie page and set movie fields
          SetMovieFields(PageStr);
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 4.2.0)');
I updated version number to 3.4.2 though
antp wrote:Thanks
acc.... scusate.
uh oh.... sorry.
no problem ;)
otreux
Post by otreux »
Grazie :)
mrobama
Re: [UPD ITA] Filmtv.it aggiornato
Post by mrobama »
Updated version.
Title=FilmTV
Site=www.Film.TV.it
Language=IT
Version=3.4.3    13.3.2018
Requires=4.2.0
Comments=
License=
RequiresMovies=1
[Parameters]
MaxPreview=1|1|Show more info in search results list (0 = false, 1 = true)
program FilmTVIt;
  //Query constants
  folder = 'd:\';
  Apice = #39;
  xFilmSearchStart = '<article';                              // HTML start marker movie block
  xFilmSearchEnd = '</article>';                              // HTML end marker movie block
  xResultTypeStart = '<div class="etichetta-serp">';          // Block type start marker. Possible blocks: FILM, RECENSIONE, POST ...
  xResultTypeEnd = '<';                                       // Block type end marker
  xFilmUrlStart = '<h2 class="title-item-scheda"><a href="';  // URL start marker
  xFilmUrlEnd = '"';                                          // URL end marker
  xTitleStart = ' title="';                                   // Title start marker
  xTitleEnd = '"';                                            // Title end marker
  xOriginalTitleStart = '<li>Titolo originale: <span>';       // Original title start marker
  xOriginalTitleEnd = '<span>';                               // Original title end marker
  xCategoryStart = '<li>Genere: <span>';                      // Category start marker
  xCategoryEnd = '</span>';                                   // Category end marker
  xDirectorsStart = 'Regia: <span>';                          // Directors start marker
  xDirectorsEnd = '</span>';                                  // Directors end marker
  xYearStart = '<span class="anno">';                         // Year start marker
  xYearEnd = '</span>';                                       // Year end marker
  cTranslTitleStart = '<div class="wrap-head">';    // Translated title start marker
  cTranslTitleEnd = '<div class=';                  // Translated title end marker
  cOrigTitleStart = '[<i>';                         // Original title start marker
  cOrigTitleEnd = '</i>';                           // Original title end marker
  cImgLinkExtStart = '<figure class="locandina">';  // Image start marker
  cImgLinkExtEnd = '</figure>';                     // Image end marker
  cImgLinkIntStart = '<img src="';                  // Image start marker
  cImgLinkIntEnd = '"';                             // Image end marker
  cDirectorStart = 'Regia di';                      // Single Director start marker
  cDirectorEnd = '</p>';                            // Single Director end marker
  cCastStart = 'Con</span>';                        // Cast start marker
  cCastEnd = '<strong>';                            // Cast end marker
  cDescStart = '<h2>Trama</h2>';                    // Description start marker  //FS2012-11-11
  cDescEnd = '</p>';                                // Description end marker
  cCommStart = '<blockquote>';                      //fs2013-02-11
  cCommEnd = '</blockquote>';                       // Comment end marker
  searchUrl, MovieUrl, MovieName, OriginalStr, TranslatedStr, PageStr:  string;
  TmpPageStr: string;
  Temp: string;
  PackedPage: string;
  CharPos: Integer;
  n: Integer;
  TmpPageStr := '';
    if CharPos = 0 then
// IN:  none
  i, h, m: integer;
  imageLink: string;
  sep1, sep2: string;
  anno := '';
  TranslatedStr := TextBetween(htmlStr, cTranslTitleStart, cTranslTitleEnd);
     begin                                              //Italia
  if   PosBar > 0 then
//Get Director
  temp := TextBetween(htmlstr, cDirectorStart, cDirectorEnd);
  HTMLDecode(temp);
  temp := fulltrim(temp);
//Get Actors
  temp := TextBetween(htmlStr, cCastStart,cCastEnd);
  HTMLDecode(temp);
//Get comments
  SaveHtmlstr := htmlstr;
  temp := Textbetween(htmlStr, cDescStart, cDescEnd);
  HTMLDecode(temp);
  temp := TextBetween(HtmlStr, cCommStart, cCommEnd);
  HTMLDecode(temp);
  htmlstr := SaveHtmlstr;
  //Get URL
  imagelink := TextBetween(htmlStr, cImgLinkExtStart, cImgLinkExtEnd);
  imagelink := TextBetween(imagelink, cImgLinkIntStart, cImgLinkIntEnd);
  StartPos: integer;
  len:integer;
  tempStr: string;
  if StartPos<>0 then
    StartPos := StartPos+Length(lIn);
    tempStr := copy(strIn,StartPos,StartPos+length(strIn));
    if len=0 then
      result := ''
    result := '';
  HTMLDecode(result);
// FILL PICKTREE CONTROL WITH LINKS & TITLES AND RETURNS LAST FILM LINK
function PopulatePickTree(): string;
  filmHTML, filmUrl, partialUrl, resultType: string;
  filmTitle, filmOriginalTitle, filmCategory, filmYear, filmDirectors: string;
  filmSearched: string;
      filmSearched := MovieName;
      if ((GetParam('MaxPreview') <> '0') AND ((GetField(fieldYear) <> '') OR (GetField(fieldDirector) <> '') OR (GetField(fieldCategory) <> ''))) then
        filmSearched := filmSearched + ' (stored fields: ' + GetField(fieldYear) + ', ' + GetField(fieldDirector) + ', ' + GetField(fieldCategory) + ')';
      PickTreeAdd('Risultati ricerca per "' + filmSearched + '":', '');
      filmUrl := '';
        filmHTML := getTextDelimited(xFilmSearchStart, xFilmSearchEnd, PageStr);
        resultType := getTextDelimited(xResultTypeStart, xResultTypeEnd, filmHTML);
        if ((resultType <> 'RECENSIONE') AND (resultType <> 'POST')) then
          partialUrl := getTextDelimited(xFilmUrlStart, xFilmUrlEnd, filmHTML);
            filmUrl := UrlBase + partialUrl;
            filmTitle := getTextDelimited(xTitleStart, xTitleEnd, filmHTML);
            filmOriginalTitle := getTextDelimited(xOriginalTitleStart, xOriginalTitleEnd, filmHTML);
            filmCategory := getTextDelimited(xCategoryStart, xCategoryEnd, filmHTML);
            filmYear := getTextDelimited(xYearStart, xYearEnd, filmHTML);
            filmDirectors := getTextDelimited(xDirectorsStart, xDirectorsEnd, filmHTML);
            if GetParam('MaxPreview') = '0' then
                filmTitle := filmTitle + ' (' + filmYear + ')';
                if filmOriginalTitle<>'' then
                  filmTitle := filmTitle + ' - ' + filmOriginalTitle;
                filmTitle := filmTitle + ' (' + filmYear;
                if filmDirectors<>'' then
                  filmTitle := filmTitle + ' - ' + filmDirectors;
                if filmCategory<>'' then
                  filmTitle := filmTitle + ' - ' + filmCategory;
                filmTitle := filmTitle + ')';
      until (partialUrl='');
      PopulatePickTree := filmUrl;
// OUT: movie url
  FilmId: string;
  result := '';
      ShowMessage('Title not found / Nessun film trovato.');
      analyzePage := ''
      analyzePage := PopulatePickTree();
                MoviesFound := 0;
//          begin
//          end;
// MAIN:
// IN:  none
// OUT: none
      if (Input('Film.TV.It', 'Enter the title of the movie / Inserire titolo del film:', MovieName)) then
          //Get search page
          MoviesFound := 0;
          MovieUrl := analyzePage(PageStr);
          // Get movie page
          Pagestr := Stringreplace(Pagestr, '&rsquo;', '´');
grazie. ;)
otreux
Post by otreux »
IOHandler error for me :(
100celle83
Post by 100celle83 »
ciao fulvio perchè mi da sempre questo errore IOHandler error su filmtv.it ?
Grazie
Saluti
100celle83 wrote: 2018-04-30 18:11:55 ciao fulvio perchè mi da sempre questo errore IOHandler error su filmtv.it ?
Grazie
Saluti
Devi aggiornare lo script, se non l'hai fatto, ed installare l'ultima versione di Ant Movie Catalog, se non l'hai fatto.
Comunque, sempre indicare su quale film si verifica l'errore.
100celle83
Su tutti..specialmente i film nuovi. Lo script è aggiornato a marzo.
100celle83
Quale è l ultima versione di ant movie? Io ho la 4.2.1.2... lo script che ho è di marzo 2018..
100celle83 wrote: 2018-04-30 22:00:39 Su tutti..specialmente i film nuovi. Lo script è aggiornato a marzo.
Un titolo di esempio perchè sembri solo tu ad avere quell'anomalia.
:shaking:
otreux
Post by otreux »
Ciao Fulvio :)
No, succede anche a me, ad esempio con "amici miei"
Seems to give the error for all movies, no? The site probably simply switched to HTTPS
fulvio53s03, does it still work for you?
100celle83
prova con questo : Maze Runner - La rivelazione
a me su filmtv.it da errore...
100celle83
ma esiste anche un altro script per trovare film homevideo, netflix o tipo filmtv ossia i film non troppo conosciuti, non da cinema? Una volta mi trovavo bene con musicafilm ma forse il sito è chiuso... grazie
Comunque se si risolve filmtv è quello più completo !
100celle83
stesso errore lo da anche su ibs.it...
100celle83 wrote: 2018-05-01 11:05:56 stesso errore lo da anche su ibs.it...
di ibs.it non saprei dire.
hai provato Kultvideo? dedicato ai film di serie B, C, ...., Z
ma anche myvideo, wikipedia, comingsoon funzionano.... non so se i repertori inclusi in ciascuno ti possono soddisfare.
di Filmscoop, LaFeltrinelli, Libreria Universitaria ho perso le novità e mi piacerebbe qualcuno li verificasse.
In ogni caso, per FilmTV mi dedicherò.... se non mi confondo con tutti questi scripts da modificare.... :shaking: :wow: :wow: :innocent:
about ibs.it I can not say.
have you tried Kultvideo? dedicated to the films of series B, C, ...., Z
but also myvideo, wikipedia, comingsoon work .... I do not know if the repertoires included in each can satisfy you.
Filmscoop, LaFeltrinelli, Libreria Universitaria: I lost the news and I would like someone to verify them.
In any case, for FilmTV I will dedicate myself .... if I do not get confused with all these scripts to be modified.... :shaking: :wow: :wow: :innocent:
