how to change *( into * ( with space
namron
Post by namron »
hello,
i have a problem where i don´t know how to fix it.
got plenty of files with a certain naming, followed by a "(" directly after the last letter.
now i want to have a space inbetween.
could be so easy [change "(" into " (" ] if i wouldn´t have a large number of files, where the space is already existing.
if i´m doing it like mentioned above, i´ll get a double spacing, which is not allowed.
does anybody have an idea how to approach this problem?
e.g
existing file : track1(solo).mp3
should be : track1 (solo).mp3 [just 1 spacing inbetween]
cheers nam
You could then replace double spacing by a single spacing
Or else if you want to do exactly the change asked, that can be achieved using regular expressions.
On the regular expression action page, enter this as expression:
([^\s]+)\((.+)
and this as new name:
$1 ($2
namron
Post by namron »
Hello antp,
thanks for your hints!
"Replace double spacing by a single spacing"
So simple, so effective! i thought way to complicated!!!
And it works.
Changing by regular expression just worked for a single file.
Don´t know why it didn´t run through the other files.
But nevertheless, you helped me a lot
Thank you
Cheers Nam
Strange, it would be worth seeing what the other names look like, by curiosity
