export to html -> images not included any more
oliviervdb
Post by oliviervdb »
Whatever option I choose the images are no longer included in the export.
I tried copy with images subfolder and it worked ONCE ... After that that didn't work anymore...
This problem has popped up a few months ago as well but at that time I 'fixed' it by creating a new subfolder for each time I exported the list to html. That "fix" no longer works.
Does anyone else have the same problem?
windows 10 home version 1703 64bit
MovieCatalog.exe: versie 4.2.1.1 (gemaakt op 10/08/2015 19:10:36)
AMCExchange.dll: versie 1.9.0.1 (gemaakt op 10/08/2015 19:10:42)
AMCReport.exe: versie 1.8.0.1 (gemaakt op 20/04/2014 0:50:22)
MediaInfo.dll: versie 0.7.71 (gemaakt op 9/11/2014 22:47:00)
Are there images used in the HTML template? (i.e. is the image tag used)
And which one are you exporting, the "full" or "individual" template? Or both? Though that if the HTML is correctly exported, I guess the problem is not there.
oliviervdb
yes images used in html.
I have resolved this problem by removing the latest windows update ?!
