Trailer
emueyes
Trailer
Post by emueyes »
Hi
I have been looking through the scripts trying to find one that will get the trailer for a movie but can't find one. IMDB seems to have trailers and it might be that is the best way to do it, I use the IMDB script for movies so it'd be a good fit to get the trailer at the same time.
I've not yet done any script rewriting, is there an existing way that anyone could suggest or am I better just to dive into it and see how I go?
You mean getting the address of the trailer?
As the program itself can't download it.
At some point the Allociné script was getting such info (but if you don't speak French, that site is not very useful for you), if it is somewhere on the IMDb movie page it is probably possible to get the link from it, but it would require that someone dives in it, indeed...
Personally I don't really see the interest, since usually with the movie page link you can find the trailer rather quickly (though it is indeed one or two more clicks needed).
