No drap & drop ?!
No drap & drop ?!
Hi
i just changed to newest version of renamer and noticed that the drag&drop of file doesnt work anymore!? :??:
anyways, this program kicks *** :) .. i actually need it more than i ever thought :grinking:
that drag&drop feature would have been a good thing to preserve..
cheers
Mystiqq
It is very strange bug : it seems that the first time that you start the program the drag & drop does not work.
But if you close the program and open it again, it works.
It seems that it does not work when it does not find its options file (e.g. just after having been installed).
I'll try to correct that for next version.
great!
Good to hear :)
i hope you get it fixed.. oh and "small" typo on the thread, i meant "Drag and drop" :D
cheers
mystiqq
Actually I really do not know why this problem exists :D
Does it works for you once the program has written its xml options file ?
now it does...
yes.. now it works..
it didnt show that options thing previously.. :)
I added this options window when I added the possibility to add folders to the list in addition of the files that the folders contain.
I do not see a better way to make this choice visible :/ (but there is a checkbox to disable this options window)
