Drag & drop images & informations not working
drag & drop images into AMC database doesn't work no more with browser Firefox (rel. 52.0).
Any Idea about the reason why?
Even importing information (drag & drop) from files with Mediainfo does not work!
Information
MovieCatalog.exe: version 4.2.1.1 (created on 10/08/2015 18:10:38)
AMCExchange.dll: version 1.9.0.1 (created on 10/08/2015 18:10:44)
AMCReport.exe: version 1.9.0.1 (created on 10/08/2015 18:10:54)
MediaInfo.dll: version 0.7.71 (created on 09/11/2014 21:47:02)
(press Ctrl+C if you want to copy these information to clipboard)
OK
If it stopped working, you most likely changed something on your end, since the program hasn't changed since 2015.
Or it is due to a recent update of Windows. There were issues with the first release of Windows 10, but it has been solved in a later update (it worked again at least since July 2016).
Drag & drop works fine here (Firefox 52.0.1)
antp wrote:... you most likely changed something on your end, since the program hasn't changed since 2015.
Or it is due to a recent update of Windows....
Thanks. I'm sure you are right, it is problem about Win 10. :angry:
I Hoped someone else could have a solution.
:ha:
Do you have it at the latest version?
As that problem only occured in earlier versions, as far as I know.
Another possibility of problems is drag & drop between admin and non-admin programs, and/or between 32-bit and 64-bit programs.
Though that my file manager is running as admin and AMC is not, and the drag & drop still works.
antp wrote:Do you have it at the latest version?
My win 10 is 64bit (from 1 year ago) and it worked till last week; after seen it didn't, I went back with updates to 16.3,2017 but it doesn't work.
Only KB4013418 was impossible to rollback.
http://windowsreport.com/fix-windows-10-kb4013418-bugs/
http://www.imagebam.com/image/cc7bcd539319406
drag & drop is OK with Libreoffice
Well as I said, drag & drop problems were in early versions of W10, current one should not cause problems (including updates from last week).
If it is due to a Windows Update, maybe it will work again later when they'll fix the bug :D
If you haven't changed anything, I don't know what could cause that.
