Script to export without extra links
VERSEAU44
Post by VERSEAU44 »
Hi !
Is there a script that allows to export the database as an XML file WITHOUT link to the extras (I have not found the option that allows it) ?
Indeed, when the database becomes large, the size of the XML file grows logically and takes longer to import for viewers (example: Pocket AMC Reader on Android).
The idea would be to export only the lines of the film WITHOUT the extras to limit their number, and therefore import more quickly.
THANKS for your answers
VERSEAU44
Post by VERSEAU44 »
Up ?
