Dear Sir.
I'm a new user in this world!
(I'm Spanish, sorry for my language)
Is it possible to add to AntMovieCatalog logos in png/jpg/bmp/... format for DVD, Blu-ray, MP4, DIVX, 4K UHD...?
And, in the future versions, could be it possible to personalize the main menu to erase or to organize in another way all fields?
Many thanks.
Yours faithfully.
Questions
Sorry, I'm not sure to understand your question.
Where do you want to display logos? In the program itself? Or when exporting to HTML?
To organize/erase fields, it is not directly possible in the program, but it can be done using some "tricks": you have to modify the translation file.
Open the corresponding .lng file and see other topics for what to change, e.g.
viewtopic.php?p=26645
viewtopic.php?p=34112
Oasys
Question
Yes, in the program itself.
There is a field with this name: media type. But I think a picture is worth a thousand words. Is it possible replace this field and to add a new system to use a picture? In this way I could put logos in all movies (no text) and to differentiate more easy my DVD, Blu-ray, MP4, 4K UHD...
In other way if I can organize/erase fields directly in the progran all people could create your own appearance in the main menu and you and any people could offer different skins (without HTML). It would be amazing! because anybody could get your own compilation of fields in their own way.
Many thanks.
Best Regards.
Many thanks.
Best Regards.
