U P D A T E D
[UPD ITA] Comingsoon.it
Aggiornamento: Nelle stagioni delle serie, la descrizione è costituita dall'elenco degli episodi
U P D A T E D
U P D A T E D
otreux
Surely something changed on the site (last 2016.12.14 script was OK) but i think it is the same problem as discogs.it .... site changed from http to https .... i don't know what to do...antp wrote: Indeed; something has changed on the site I suppose
mrobama
certificate problems?
This is my 1% (but I'm not sure about it)
The site forces https instead of http and if you try to access to http it redirects to https. So you should replace this line:
Address := Address := 'http://' + textBetween(dati_album, initchar, endchar);
with this one:
Address := 'https://' + textBetween(dati_album, initchar, endchar);
BUT there is a problem with ssl certificate. That is you have to access in "insecure mode". To understand the difference, try these curl commands:
curl -I "https://www.comingsoon.it/film/il-grand ... 57/scheda/"
and:
curl -i -k "https://www.comingsoon.it/film/il-grand ... 57/scheda/"
so: how we can skip ssl validation in GetPage? By the way, where function GetPage() is defined?
with this one:
and:
mrobama
I still get "IOHandler value is not valid" when accessing to https://www.comingsoon.it/..."
mrobama
Just a little fix. Change this line:
ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 4.2.0)');
in:
ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 4.2.1)');
By the way, I'm doing other fixes, script is not working ...
in:
mrobama
Little fixes, please try now
(to test the difference between old and new version search for Heidi and try to download Heidi 2015). I also modify the first input box (when you drag a movie in AMC the title is in original title field, so I also check for this field) and now only non void fields are set (if fieldvalue <> '' then setfield(fieldname, fieldvalue)).
All the credits to Fulvio53s03, these are only minor fixes
Authors=Fulvio53s03
Title=comingsoon
Description=import film e serie TV
Site=http://www.comingsoon.it
Language=IT
Version=1.2.0
Requires=4.2.1
Comments=puo' essere usato per ricerca informazioni tramite google (mode=0) oppure per estrarle direttamente da comingsoon.it (mode=1) inserendo l'URL direttamente.
License=* The source code of the script can be used in |* another program only if full credits to Fulvio53s03*
RequiresMovies=1
Mode=0|0|0=normal mode|1=batch mode (url)
[Parameters]
// TypeSearch=1|1|1=search for exact expression|2=search for any word
// TypeOrder=3|3|1=order by Artist|2=order by film_o_serie Title|3=order by relevance
// needs the following units
// StringUtils7552.pas
program comingsoon;
StringUtils7552;
comingsoonUrl = 'https://www.comingsoon.it'; // base url
UrlBase = 'https://www.comingsoon.it'; // base url
batchlogfic = 'c:\comingsoon_batch.txt'; // log for batch mode
debug_search = false; // debuga mode on/off su ricerca dischi
debug_film_o_serie = false; // debug mode on/off su estrazione dati film_o_serie
folder = 'f:\prova\'; // directory where to save files
CRLFspace = CRLF + ' ';
//2016-02-10 tappo_fine_ricerca = '<li class="g">Tappodifinericercadaticongoogle</li><li class="g">';
tappo_fine_ricerca = '<div class="g">Tappodifinericercadaticongoogle</div><div class="g">'; //2016-02-10
nuovo_anno, mese_anno, solo_anno, data_rilascio, label, stagione: String;
Credit_address, Readdress, Page: String;
film_o_serieName, ArtistName, firstcall, name, autori: String;
Formato, Releases, artista: String;
tipo_ricerca, pag_ricerca, save_value, ordine_lista, Salva_autore: String;
value, episodi, lista_episodi: string;
film_o_serie_ok: boolean;
BatchMode, giri: Integer;
titolo_e_autore, titolo, autore, durata, cover: String;
save_comments, commento_episodi, commento_skeda: String;
save_description, save_desc_skeda, save_desc_episodi: String;
batchlog, confbatch: TstringList;
save_pag, artist, initchar, endchar: string;
film_o_serieok: boolean;
// list of film_o_series
procedure GetList;
Address, urlmusic, album, albumtest, genre: String;
Save_address, Title_album, indir_album, indir_title_album: String;
dati_album, init_control, end_control, init_ol, end_ol: String;
Desc_ricerca: String;
ctr_loop: integer;
found: boolean;
i, lgth_dati_album: integer;
PickTreeClear; // clear list
desc_ricerca := film_o_serieName;
Address := 'https://www.google.it/search?as_q=' + film_o_serieName;
Address := Address + '&as_epq=&as_oq=&as_eq=&as_nlo=&as_nhi=&lr=&cr=&as_qdr=all';
Address := Address + '&as_sitesearch=www.comingsoon.it&as_occt=any&safe=images&as_filetype=&as_rights=';
// Address := comingsoonUrl + '/cerca/?q=' + film_o_serieName + '&gsc.page=1';
// Address := Address + '#gsc.tab=0&gsc.q=' + film_o_serieName + '&gsc.page=1';
// https://www.google.it/search?as_q=Teen%20Wolf&as_epq=&as_oq=&as_eq=&as_nlo=&as_nhi=&lr=&cr=&as_qdr=all&as_site
// search=www.comingsoon.it&as_occt=any&safe=images&as_filetype=&as_rights=
Address := UrlEncode(Address);
Page := GetPage(Address);
Save_address := Address;
if debug_search then
DumpPage(folder+'googleListPage.html', Page); // debug
HTMLdecode(Page);
found := True;
// PickTreeAdd('List of albums found for' + '"' + AlbumName + '"', '');
PickTreeAdd('Lista articoli trovati per "' + Desc_ricerca, '"');
DumpPage(folder+'discogsList.txt', Page); // debug
if Pos('find anything', Page) <> 0 then
LogMessage('Error while reading selection page - no results found for ' + Desc_ricerca);
Found := False;
init_ol := '<ol>'; //2015-11-25
end_ol := '</ol>';
pag_ricerca := TextBetween(Page, init_ol, end_ol) + tappo_fine_ricerca + end_ol; //elenco titoli richiesti e tappo ricerca
DumpPage(folder+'googlericerca.html', pag_ricerca); // debug
// Normalizza_Page(pag_ricerca);
// if debug_search then
// DumpPage(folder+'googlericercanorm.html', pag_ricerca); // debug
save_pag := pag_ricerca;
//2016-02-10 init_control := '<li class="g">';
//2016-02-10 end_control := '<li class="g">';
init_control := '<div class="g">'; //2016-02-10
end_control := '<div class="g">'; //2016-02-10
dati_album := init_control + TextBetween (pag_ricerca, init_control, end_control) + end_control;
//dati_album contiene recursivamente i dati delle pagine referenziate da google
lgth_dati_album := length(dati_album);
DumpPage(folder+'google_dati_album.html', dati_album); // debug
delete(Pag_ricerca, 1, (lgth_dati_album - length(end_control)));
DumpPage(folder+'googlericerca-1.html', Pag_ricerca); // debug
while (dati_album <> tappo_fine_ricerca) do //estraggo fino al tappo di fine ricerca
//2016-02-10 initchar := '<a href="/url?q=';
//2016-03-04 initchar := '<a class="_Zkb" href="';
//2016-03-04 endchar := '"';
initchar := ':https://'; //2016-03-04 :http://
endchar := '/%252';
// endchar := '&sa=';
// Address := 'http://' + textBefore(Address, endchar, '');
initchar := '<h3 class="r">';
endchar := '</h3>';
Title_album := textBetween(dati_album,initchar, endchar); //descrizione del link
HTMLRemoveTags(Title_album);
// Title_album := copy(Title_album, 1, 42);
PickTreeAdd(Title_Album, Address);
found := True;
lgth_dati_album := length(Dati_album) - (length(init_control) + length(end_control));
// end;
if not found then
LogMessage('No album found for ' + Desc_ricerca);
AnalyzeMoviePage(Address); // Album page
LogMessage('No serie/film selected');
// ANALYZE Movie PAGE
urlmusic, Lenght, Pays: String;
Autore, style, Commenti, str_min, campo_note: String;
minu, minuti, ore, lgth_comm, save_lgth_comm, i: integer;
j: Real;
if pos('/scheda', Address) > 1
then begin
stagione := '';
tipo_ricerca := 'sk ep';
else if pos('/episodi', Address) > 1
then begin
tipo_ricerca := 'ep sk';
// stagione := ' (' + (textbetween(Address,'/episodi/', '/') + ')';
stagione := ' (' + (textafter(Address, '/episodi/') + ')';
else begin
ShowMessage('indirizzo di estrazione non appropriato. Né scheda né episodi!');
save_comments := '';
commento_episodi := '';
commento_skeda := '';
if tipo_ricerca = 'sk ep' then
estrazione_scheda(Address);
save_comments := commento_skeda + CRLF + commento_episodi;
if (FullTrim(save_comments) <> '') then
SetField(fieldcomments, save_comments); // commenti + elenco episodi end
save_description := save_desc_skeda;
if (FullTrim(save_description) <> '') then
SetField(fieldDescription, save_description);
if tipo_ricerca = 'ep sk' then // inizio variazioni fs2016-11-17
estrazione_episodi(Address);
save_comments := commento_skeda; // + commento_episodi;
// SetField(fieldcomments, save_comments); // commenti + elenco episodi end
if (FullTrim(commento_episodi) <> '') then
SetField(fieldDescription, commento_episodi);
save_description := save_desc_skeda + CRLF + commento_episodi;
// SetField(fieldDescription, save_description);
if (FullTrim(save_desc_skeda) <> '') then
SetField(fieldComments, save_desc_skeda);
// ESTRAE INFORMAZIONI DA SCHEDA + EPISODI SE E' UNA SERIE
procedure estrazione_scheda(Address: string);
Page := UTF8decode(Page);
if debug_film_o_serie then
DumpPage(folder+'comingsoonPageDetail.txt', Page); // debug_film_o_serie
HTMLdecode(Page);
if (BatchMode = 0) and (tipo_ricerca = 'sk ep') then
Normalizza_Page(Page);
// Page := UTF8Decode(Page); //fs2015-01-15
film_o_serieok := True;
DumpPage(folder+'comingsoonPageDetailHTMLdecode.html', Page); // debug_film_o_serie
Value := Page;
//*** cover locandina jpg
cover := TextBetween(value, '<link rel="image_src" href="', '">');
// setfield(fieldborrower, cover);
GetPicture(cover);
// if length(Getfield(fieldtranslatedTitle)) < 1 then
// begin
//fs2016-06-26 initchar := '<h1 itemprop="name" class="titolo scheda col-sm-10">';
initchar := '<h1 class="titolo scheda col-sm-10">'; //fs2016-06-26
endchar := '</h1>';
label := textbetween(Value, initchar, endchar);
label := label + stagione;
if length(label) > 0
then begin
label := stringReplace(label, '/', '');
SetField(fieldtranslatedTitle, label);
end; //artista in original title
label := textbetween(Value, 'Titolo originale: ', '</p>');
if (label <> '') then
SetField(fieldoriginalTitle, label); //artista in original title
initchar := '<div class="contenuto-scheda-destra col-xs-8">';
endchar := '<div class="box-descrizione">';
label := TextBetween(Value, initchar, endchar) + endchar;
initchar := '<!-- Paragrafo -->';
// label := TextBetween(label, initchar, endchar); // era per solo serie
label := TextAfter(label, initchar); //sia serie che film
initchar := '<p>';
endchar := '</p>';
label := stringReplace(label, '<strong>', ' $%&$%&$%&');
HTMLRemoveTags(label);
label := FormatText(label);
label := stringReplace(label, CRLF, '');
label := stringReplace(label, ' $%&$%&$%&', CRLF); //se presenti descrizioni di serie multiple
label := stringReplace(label, '$%&$%&$%&', ''); //eventuale prima riga della descrizione
save_desc_skeda := label;
initchar := '<span>GENERE</span>:';
endchar := '</li>';
label := TextBetween(value, initchar, endchar);
// label := fulltrim(label);
SetField(fieldcategory, label);
initchar := '<li><span>REGIA</span>: ';
endchar := '</li>';
SetField(fieldDirector, label);
initchar := '<li><span>ATTORI</span>:';
endchar := '</li>';
label := initchar + TextBetween(Value, initchar, endchar) + endchar;
label := stringReplace(label, 'ATTORI: ', '');
SetField(fieldactors, label);
initchar := '<li><span>ANNO</span>: ';
endchar := '</li>';
label := TextBetween(Value, initchar, endchar);
SetField(fieldyear, label);
initchar := '<li><span>PAESE</span>: ';
endchar := '</li>';
SetField(fieldcountry, label);
initchar := '<li><span>PRODUZIONE</span>: ';
endchar := '</li>';
SetField(fieldproducer, label);
initchar := '<li><span>IDEATORE</span>: ';
endchar := '</li>';
SetField(fieldwriter, label);
initchar := '<li><span>DURATA</span>: ';
endchar := ' Min</meta></li>';
SetField(fieldlength, label);
// commenti_ le serie contengono anche l'elenco episodi //
Value := stringReplace(Value, '>CURIOSITÀ:<', '>Curiosità:<');
initchar := '<div class="h5 pad-tlr-18">Curiosità:</div>';
endchar := '</div>';
commento_skeda := label;
// save_comments := label;
// per le serie, aggiungo l'elenco episodi
initchar := '<nav class="col-xs-12 tab-menu tab-12 serietv">';
endchar := '</nav>';
label := Textbetween(Value, initchar, endchar);
initchar := '<li class="item1"><a href="';
endchar := '">';
label := Textbetween(label, initchar, endchar);
if length(label) > 0 then
label := 'https://www.comingsoon.it' + label;
Address := label;
// ESTRAE INFORMAZIONI DA EPISODI DI UNA SERIE + SCHEDA DELLA SERIE
Procedure estrazione_episodi(Address: string);
Begin
// normalizza_page(Value); //fs2015.01.15
DumpPage(folder+'comingsoonepisodes.txt', Page); // debug_film_o_serie
HTMLdecode(Page);
cover := TextBetween(Page, '<link rel="image_src" href="', '">');
GetPicture(cover);
if (BatchMode = 0) and (tipo_ricerca = 'ep sk') then
initchar := '<div class="articoli-piu-recenti-xl box-main" id="box-lista-episodi-serietv" role="tablist">';
endchar := '<div class="box-share-tasti-sociali">';
Value := initchar + TextBetween(Page, initchar, endchar) + endchar;
DumpPage(folder+'comingsoonepisodesExtr.txt', Value); // debug_film_o_serie
Value := StringReplace(Value, '<div class="col-sm-6 titolo">', '$%&$%&$%&');
// formatta episodi //
//1. Sotto assedio (A'ohe Kahi e Pe'e Ai) - REGIA: Bryan Spicer - SCENEGG.: Peter M. Lenkov, Ken Solarz.......
Value := stringReplace(Value, '<div class="col-sm-6 descrizione">', '<div class="col-sm-6 descrizione">seispazi (');
// Value := stringReplace(Value, '<li class="h6 anno"><strong>REGIA', '<li class="h6 anno"><strong>)seispazi - REGIA');
Value := stringReplace(Value, '<li class="h6 anno"><strong>REGIA', '<li class="h6 anno"><strong>) - REGIA');
Value := stringReplace(Value, '<li class="h6 anno"><strong>SCENEGGIATURA', '<li class="h6 anno"><strong> - SCENEGG.');
Value := stringReplace(Value, '<li class="h6 anno"><strong>TRAMA</strong>: ', '<li class="h6 anno"><strong>$%&$%&$%&TRAMA</strong>: ');
// Value := stringReplace(Value, ' )', ')');
initchar := '<li class="h6 anno"><strong>DURATA';
endchar := '</li>';
durata:= initchar + TextBetween(Value, initchar, endchar) + endchar;
while length(durata) > (length(initchar) + length(endchar)) do
Value := stringReplace(Value, durata, ''); // elimino durata dei singoli episodi
// fine formatta episodi //
HTMLRemoveTags(Value);
value := FormatText(value);
Value := StringReplace(Value, CRLF, '');
Value := stringReplace(Value, '$%&$%&$%&', CRLF);
Value := stringReplace(Value, 'seispazi', ' '); //eventuale prima riga della descrizione
Value := stringReplace(Value, ' ', ' ');
Value := stringReplace(Value, ' ', '');
commento_episodi := Value; //fs2016-11-17
//fs 2016-06-02 -------------- aggiungo commenti per la serie ----------------------------------
Page := stringReplace(Page, '>CURIOSITÀ:<', '>Curiosità:<');
label := TextBetween(Page, initchar, endchar);
commento_episodi := commento_episodi + CRLF + label;
//fine fs 2016-06-02 ------------------------------------------------
label := Textbetween(Page, initchar, endchar);
endchar := '">';
Address := label;
// ********************* fine estrazione episodi *****************************************
Procedure Normalizza_page(Pagina: string); // elimina i crlf, trasforma delimiters maiuscoli in minuscoli
pagina := RegExprSetReplace('<([^>]+)>', pagina, '<\L\1>', true);
CharAbNormal := crlf;
CharNormal := ' ';
pagina := StringReplace(pagina, CharAbNormal, CharNormal);
CharAbNormal := '<B';
CharNormal := '<b';
CharAbNormal := '</B';
CharNormal := '</b';
pagina := StringReplace(Value, CharAbNormal, CharNormal);
CharAbNormal := '<FONT';
CharNormal := '<font';
CharAbNormal := '</FONT';
CharNormal := '</font';
CharAbNormal := '<TR';
CharNormal := '<tr';
CharAbNormal := '</TR';
CharNormal := '</tr';
CharAbNormal := '<TD';
CharNormal := '<td';
CharAbNormal := '</TD';
CharNormal := '</td';
CharAbNormal := '<DIV';
CharNormal := '<div';
CharAbNormal := '</DIV';
CharNormal := '</div';
CharAbNormal := '<Ol';
CharNormal := '<ol';
CharAbNormal := '</Ol';
CharNormal := '</ol';
if BatchMode > 0 then
ShowWarning(m);
//fs2016-12-31 batchlog.Add(m);
//fs2016-12-31 batchlog.SaveToFile(batchlogfic);
// process batch mode
procedure comingsoonBatch;
film_o_serieName := GetField(fieldUrl); // if no url or another site then ignore
if (film_o_serieName <> '') and (Pos(UrlBase, film_o_serieName) > 0) then
AnalyzeMoviePage(film_o_serieName)
LogMessage('ignored url="'+film_o_serieName+'"');
// process normal mode
procedure comingsoonNorm;
film_o_serieok := False;
if (GetField(fieldTranslatedTitle) <> '') then
film_o_serieName := GetField(fieldTranslatedTitle) // get film_o_serie name
film_o_serieName := GetField(fieldOriginalTitle); // get film_o_serie name
ArtistName := getField(fieldOriginalTitle); // get artist
if not Input('comingsoon = ' + ArtistName + ' - ' + film_o_serieName, 'Scrivi il nome del film o della serie:'
+ crlf, film_o_serieName) or (film_o_serieName = '') then exit;
formato := getfield(FieldOriginalTitle);
if pos(formato, 'serie') > 0 then
formato:= 'serie';
GetList;
until film_o_serieok;
// start here
if not CheckVersion(4,2,1) then
if BatchMode = 1 then
comingsoonBatch;
if BatchMode = 0 then
comingsoonNorm;
otreux
otreux
Apprezzo la variazione relativa alla ricerca tramite titolo originale se il titolo tradotto è vuoto.mrobama wrote:Little fixes, please try now......
Le altre modifiche (non aggiornare campi con altre informazioni vuote) temo siano pleonastiche: già nelle opzioni di esecuzione (in alto a destra nella videata di esecuzione dello script) si contempla la possibilità di aggiornare o non aggiornare con campi vuoti: nei prossimi aggiornamenti dello script, quindi, eliminerò tali verifiche.
Sto lavorando sulla compatibilità nelle ricerche con indirizzi http e/o https: ogni aiuto sarà gradito.
I appreciate the change to "Search using original title" if "translated title" is empty.
Other changes (don't update fields with other information if empty) I fear are pleonastic: already in the run options (top right of the screen execution script) you contemplate the possibility to update or not to update with empty fields: in future script updates, therefore, I will delete these tests.
I'm working on compatibility with addresses in searches http and/or https: any help is appreciated.
P.S. http & https OK!
