Lost the picture down under
moviefever
Post by moviefever »
After re-installing the software I lost the possibility to create a small picture of the movie.
I mean the picture that appears on the left under corner when opening a movie in the catalog.
Please forgive my English language if I make some mistakes. :o
Thanks a lot for helping.
You can enable/disable it via Movie->Picture->Display Movie Picture
moviefever
Thanks a lot. It's so easy, must have been confused. :/
