Post
by Guest » 2003-05-01 22:47:03
Can any one explain me how can i change a value in any field.
Exemple: Change "Comedy" for "Comédia" (portuguese) in the Category
Thanks....
Posts: 9886 Joined: 2002-05-30 10:13:07
Post
by antp » 2003-05-01 23:20:52
You mean modify the value in all the movies ?
See the "find & replace" sample script
(Tools -> Scripting)
Or modify the list contents ?
Go to Tools -> Preferences -> Drop-down lists
Post
by Guest » 2003-05-02 02:40:32
I try this in the find&replace Script, but don't work:
// SCRIPTING
// Find & Repace a value in a field
program FindReplace;
OldValue = 'Comedy';
NewValue = 'Comédia';
Field = fieldCategory;
WholeFieldOnly = False;
Can any one help me...
Post
by antp » 2003-05-02 08:48:59
What do you mean by "don't work" ?
Did you select all the movies that have to by modified (e.g. the whole list)
Because by default it applies that only to selected movie(s)
antp on 2003-05-03 18:48:41, edited 1 time in total.
Post
by Guest » 2003-05-03 18:06:56
Thanks it work now...
palantir
Posts: 14 Joined: 2003-04-06 08:10:49
Post
by palantir » 2003-05-04 14:36:51
biba!
se quiseres, eu fiz uma versão do programa (versao 3.4.2) em português. é preciso fazer algumas alterações, mas sempre é melhor do que a brasileira...
não tenho os valores dos campos traduzidos, só está traduzida a estrutura do programa.
se quiseres mando-te isso por mail.
Post
by antp » 2003-05-04 18:09:44
what are you asking
palantir
Post
by palantir » 2003-05-05 14:09:03
Sorry
I was offering him the portuguese translation I made... only I was saying that in portuguese
