IMDB with Year field support in batch mode
mrobama
Post by mrobama »
When used in batch mode, IMDB doesn't use the year field. That is, if you have a movie (title: "Cavalleria rusticana", year: 1982) and you execute IMDB in batch mode (batch mode <> 0), when the script looks for Cavalleria Rusticana on IMDB site it gets the first result (the most popular), that is a 1968 movie titled "Cavalleria rusticana": it's a different movie!
So I tried to change the IMDB script on myself and I created a test script (IMDBFix.ips): in batch mode it now looks for the right title in the right year and if it can't find it, it looks for previous year and then for next year. That is, if you have a "Cavalleria rusticana" (1981) or "Cavalleria rusticana" (1983) the script will still find "Cavalleria rusticana" (1982) for you.
I'm not a Pascal developer and I have no time to improve the script. Neither I studied all the utils you created, so this is not a great piece of code.
I added StringUtils7552 in "uses", added MovieYear global variable (set it in the main body), then updated the procedure AnalyzeResultsPage.
I haven't test it in all conditions, but it works fine during the first tests.
You can use, improve or ignore it.
Authors=Antoine Potten, KaraGarga, baffab, Thermal Ions, bad4u, Sancho, Joe, cage, Elman
Title=IMDBFix
Description=Import data & picture from IMDB (optional image from Amazon)
Site=us.imdb.com
Language=EN
Version=3.87
Requires=4.2.0
Comments=Based on the script made for version 3.3/3.4 by Antoine Potten, Danny Falkov, Kai Blankenhorn, lboregard, Ork, Trekkie, Youri Heijnen
RequiresMovies=1
ActorsLayout=2|0|0=Only actor names, separated by commas|1=Only actor names, separated by linebreaks|2=Actors names with character names between parenthesis separated by commas|3=Actors names with character names between parenthesis separated by linebreaks|4=Actor names like on IMDB page, with "...." and separated by linebreaks
AllActors=1|0|0=Only import actors from main page (does not work if you import producer name)|1=Import all possible actors|2=Import 10 first actors (does not work with ActorLayout=4)
AspectRatio=1|1|0=Do not import picture aspect ratio|1=Import picture aspect ratio to video format field|2=Import picture aspect ratio to resolution field
Awards=2|0|0=Do not import awards|1=Import awards to Description field, after the summary|2=Import awards to Comments field, after comments
BatchMode=0|0|0=Normal working mode, prompts user when needed|1=Does not display any window, takes the first movie found|2=Same as 1, but it uses the URL field if available to update movie information
CommentType=0|0|0=Standard Type (Only one comment from main page)|1=Detailed Type (10 most useful comments from comments page)|2=No user comment, clear current field contents|3=No user comment, keep current field contents (may cause problem for multiple imports on the same movie if other options append text to the comment field)
ConvertToASCII=0|0|0=Do not change special characters and accents.|1=Replace special characters and accents by basic ASCII characters
DescriptionSelection=0|0|0=Take the short summary, from main page (faster)|1=Show a list of available summaries|2=Take the longest summary
EpisodeTitleSearch=0|0|0=Use "Find more" button on results list for next result pages if available (default)|1=Use "Find more" button on results list for episode title search instead
GetTagline=1|1|0=Do not get tagline|1=Put it in Description field, before the summary|2=Put it in the Comment field, before the comments
HideAkaTitles=0|0|0=Show 'aka' titles on result list (= other titles for the film)|1=Hide 'aka' titles on result list
ImageKind=3|3|0=No image|1=IMDB small image, from the main movie page, no image if none available|2=IMDB small image, from the main movie page, "No Poster Available" if none available|3=IMDB large image, from link on main movie page, else small image, else "No Poster Available"|4=Cover from "Merchandising Link" page, else "DVD detail" page, else small image|5=Cover from "DVD detail" page, else "Merchandising Link", else small image
MPAA=2|0|0=Do not import MPAA rating|1=Import MPAA rating to MediaType|2=Append MPAA rating and info to Comments
MultipleValuesAudioFormat=1|1|0=Only take first value for Audio Format|1=Take full list, separated by commas|2=Take full list, separated by slashes|3=Do not import Audio Format / Sound Mix
MultipleValuesCategory=1|1|0=Only take first value for Category|1=Take full list, separated by commas|2=Take full list, separated by slashes|3=Do not import Category
MultipleValuesCountry=1|1|0=Only take first value for Country|1=Take full list, separated by commas|2=Take full list, separated by slashes|3=Do not import Country
MultipleValuesLanguages=1|1|0=Only take first value for Languages|1=Take full list, separated by commas|2=Take full list, separated by slashes|3=Do not import Languages
PopularSearches=1|1|0=Do not use the popular searches page, directly show full search results|1=Show popular searches first, I'll click on "Find more" if needed (much faster)
RoundRating=0|0|0=Do not round Rating|1=Round Rating to whole number
Trivia=0|0|0=Do not import trivia|1=Import short trivia to Description field, after the summary|2=Import short trivia to Comments field, after the comments|3=Import full trivia to Description field, after the summary|4=Import full trivia to Comments field, after the comments
UserRatings=0|0|0=Import value to ratings field only (default)|1=Import value and number of votes to Media Type field|2=Import value and number of votes to comments field
[Parameters]
program IMDB;
  StringUtils1, StringUtils7552;
  // ***** Manually set UserCountry to your required Classification Country below *****
  //UserCountry = '';
  { Delete the line above and remove the "//" in front of one the
    following lines, or add your country if it is not listed }
  UserCountry = 'USA';
  //UserCountry = 'Canada';
  //UserCountry = 'Mexico';
  //UserCountry = 'Brazil';
  //UserCountry = 'Argentina';
  //UserCountry = 'Australia';
  //UserCountry = 'India';
  //UserCountry = 'Italy';
  //UserCountry = 'Spain';
  //UserCountry = 'Portugal';
  //UserCountry = 'France';
  //UserCountry = 'Germany';
  //UserCountry = 'Netherlands';
  //UserCountry = 'UK';
  //UserCountry = 'Ireland';
  //UserCountry = 'Finland';
  //UserCountry = 'Norway';
  //UserCountry = 'Sweden';
  //UserCountry = 'Switzerland';
  PopularTitleSearchURL =  'http://www.imdb.com/find?s=tt&q=';
  FullTitleSearchURL = 'http://www.imdb.com/find?s=tt&exact=true&q=';
  EpisodeTitleSearchURL = 'http://www.imdb.com/find?s=ep&q=';
  MovieURL: string;
  MovieNumber: string;
  MovieYear: string;
  UpdateFile: TStringList;
function ConvertToASCII(AText: string): string;
  Result := AText;
  if GetOption('ConvertToASCII') = 1 then
    Result := Cp1252ToASCII(AText);
// ***** analyzes IMDB's results page that asks to select a movie from a list *****
  PageText: string;
  Value: string;
  PageText := ConvertToASCII(GetPage(Address));
  if pos('<title>Find - IMDb', PageText) = 0 then
      AnalyzeMoviePage(PageText)
            ShowMessage('No movie found for this search.');
          Exit;
          Value := TextBetween(PageText, '<h1 class="findHeader">Displaying', '</h1>');
          if Value <> '' then
            HTMLRemoveTags(Value);
            HTMLDecode(Value);
            PickTreeAdd(UTF8Decode(Value), '');
          Value := TextBetween(PageText, '<table class="findList">', '</table>');
          PageText := RemainingText;
          AddMovieTitles(Value);
          Value := TextBefore(PageText, '"><b>more titles</b></a>', '<a href="');
          if Value <> '' then
            PickTreeMoreLink('http://www.imdb.com' + Value);
          if GetOption('EpisodeTitleSearch') > 0 then
            PickTreeMoreLink(EpisodeTitleSearchURL + UrlEncode(MovieName));
            AnalyzeResultsPage(Address);
        if (MovieYear <> '') then
            Value := GetUrlBefore(PageText, '(' + MovieYear + ')', '');
            if Value = '' then
                Value := GetUrlBefore(PageText, '(' + IntToStr(StrToInt(MovieYear, 0) - 1) + ')', '');
                if Value = '' then
                  Value := GetUrlBefore(PageText, '(' + IntToStr(StrToInt(MovieYear, 0) + 1) + ')', '');
            if Value <> '' then
              AnalyzeResultsPage('http://www.imdb.com' + Value);
            Value := TextBetween(PageText, '<td class="primary_photo">', '<img src');
            if Value <> '' then
              AnalyzeResultsPage('http://www.imdb.com' + TextBetween(Value, '<a href="', '"'));
// ***** adds the movie titles found on IMDB's results page *****
  Value: string;
  Address: string;
  Result := False;
  Value := TextBetween(List, '<td class="result_text">', '</td>');
  if GetOption('HideAkaTitles') = 1 then
    Value := StringReplace(Value, TextAfter(Value, '<br/>aka'), '')
    Value := StringReplace(Value, 'aka', ' | aka');
  List := RemainingText;
  while Value <> '' do
    Address := TextBetween(Value, '<a href="/title/tt', '/');
    Address := Address + '/combined';
    HTMLDecode(Value);
    PickTreeAdd(UTF8Decode(Value), 'http://www.imdb.com/title/tt' + Address);
    Result := True;
// ***** analyzes the page containing movie information *****
procedure AnalyzeMoviePage(PageText: string);
  Value, Value2, Value3, FullValue, originalTitle: string;
  p, Count: Integer;
  MovieNumber := TextBetween(PageText, '<input type="hidden" name="auto" value="legacy/title/tt', '/');
  if MovieNumber = '' then
    MovieNumber := TextBetween(PageText, '<input type="hidden" name="auto" value="legacy/title/tt', '/combined"');
    MovieNumber := TextBetween(PageText, '<link rel="canonical" href="http://www.imdb.com/title/tt', '/');
//  if ((GetOption('AllActors') = 1) or (GetOption('Producer') = 1)) and (Pos('<div id="tn15" class="maindetails">', PageText) > 0) then
//    PageText := ConvertToASCII(GetPage('http://www.imdb.com/title/tt' + MovieNumber + '/combined'));
  if Pos('/combined"', TextBetween(PageText, '<link rel="canonical"', '/>')) = 0 then
  MovieURL := 'http://imdb.com/title/tt' + MovieNumber;
  // URL
  if CanSetField(fieldURL) then
    SetField(fieldURL, MovieURL);
  // OriginalTitle & Year
  if CanSetField(fieldOriginalTitle) or CanSetField(fieldYear) then
    originalTitle := TextBefore(PageText, '<i>(original title)', '<span class="title-extra">');
    HTMLDecode(originalTitle);
    Value := TextBetween(PageText, '<title>', '</title>');
   // showmessage(originalTitle);
   // showmessage(value);
    if (originalTitle <> '') and CanSetField(fieldOriginalTitle) then
      SetField(fieldOriginalTitle, FullTrim(originalTitle));
    p := Pos(' (1', Value);
    if p = 0 then
      p := Pos(' (2', Value);
    Value2 := Copy(Value, 0, p-1);
    Value := Copy(Value, p+2, Length(Value));
    HTMLDecode(Value2);
    if (originalTitle = '') and CanSetField(fieldOriginalTitle) then
      SetField(fieldOriginalTitle, FullTrim(Value2));
    if Pos('/', Value) > 0 then
      Value2 := TextBefore(Value, '/', '')
      Value2 := TextBefore(Value, ')', '');
      SetField(fieldYear, Value2);
  // Picture
  if CanSetPicture then
    case GetOption('ImageKind') of
      2:  if not ImportSmallPicture(PageText) then
              ImportPictureNotAvailable(PageText);
      3:  if not ImportLargePicture(PageText) then
      4:  if not ImportMerchandisingPicture then
              if not ImportDvdDetailsPicture then
                ImportSmallPicture(PageText);
      5:  if not ImportDvdDetailsPicture then
  // Director
    Value := TextBetween(PageText, 'Directed by</a></h5>', '</table>');
    FullValue := '';
    Value2 := TextBetween(Value, '<a href="/name/', '</a>');
    while Value2 <> '' do
      Value := RemainingText;
      Value2 := TextAfter(Value2, '">');
      if FullValue <> '' then
      FullValue := FullValue + Value2;
    HTMLDecode(FullValue);
  // Actors
    Value := FullTrim(TextBetween(PageText, '<table class="cast">', '</table>'));
    if Value <> '' then
      FullValue := '';
      Count := 0;
      case GetOption('ActorsLayout') of
        0, 1:
          while Pos('<tr', Value) > 0 do
            Value2 := TextBetween(Value, '<tr', '</tr>');
            if Pos('rest of cast', Value2) > 0 then
              Continue;
            TextBefore(Value2, '</td>', '');
            Value2 := FullTrim(TextBetween(Value2, '<td class="nm">', '</td>'));
            HTMLRemoveTags(Value2);
            if Value2 <> '' then
              Count := Count + 1;
            if (Count = 15) and (GetOption('AllActors') = 0) then
            if (Count = 10) and (GetOption('AllActors') = 2) then
        2, 3:
              Continue;
              Value2 := FullTrim(TextBetween(RemainingText, '"char">', '</td>'));
                FullValue := FullValue + ' (as ' + Value2 + ')';
              Count := Count + 1;
        4:
            FullValue := Value;
            FullValue := StringReplace(FullValue, ' <tr><td align="center" colspan="4"><small>rest of cast listed alphabetically:</small></td></tr>', '');
            FullValue := StringReplace(FullValue, '>  <', '><');
            FullValue := StringReplace(FullValue, '</tr>', #13#10);
      HTMLRemoveTags(FullValue);
        0, 2:
          FullValue := StringReplace(FullValue, #13#10, ', ');
  // Composer
  if CanSetField(fieldComposer) then
    Value := TextBetween(PageText, 'Music by</a></h5>', '</table>');
    FullValue := '';
    SetField(fieldComposer, FullValue);
  //Country
    SetField(fieldCountry, ImportList(PageText, GetOption('MultipleValuesCountry'), '/country/'));
  //Category
    SetField(fieldCategory, ImportList(PageText, GetOption('MultipleValuesCategory'), '/Genres/'));
  // Language
  if CanSetField(fieldLanguages) then
    SetField(fieldLanguages, ImportList(PageText, GetOption('MultipleValuesLanguages'), '/language/'));
  // Audio Format
  if CanSetField(fieldAudioFormat) then
    SetField(fieldAudioFormat, ImportList(PageText, GetOption('MultipleValuesAudioFormat'), '/search/title?sound_mixes='));
  // Aspect Ratio
    Value := '';
    Value := TextBetween(PageText, '<h5>Aspect Ratio:</h5>', '</div>');
    if Pos('<p>', Value) > 0 then
      Value := TextBetween(Value, '<p>', '</p>');
    if Pos('<a ', Value) > 0 then
      Value := TextBefore(Value, '<a ', '');
    HTMLDecode(Value);
    Value := FullTrim(Value);
    Value := StringReplace(Value, ', more', '');
    Value := StringReplace(Value, ', (more)', '');
    Value := StringReplace(Value, ' more', '');
    if (CanSetField(fieldVideoFormat)) and (GetOption('AspectRatio') = 1) then
      SetField(fieldVideoFormat, Value);
    if (CanSetField(fieldResolution)) and (GetOption('AspectRatio') = 2) then
      SetField(fieldResolution, Value);
  // Description
  if CanSetField(fieldDescription) then
    Value := TextBetween(PageText, '<h5>Plot:</h5>', '</div>');
    if Value = '' then
      Value := TextBetween(PageText, '<h5>Plot Summary:</h5>', '</div>');
    Value := StringReplace(Value, '<div class="info-content">', '');
    Value := StringReplace(Value, Textbetween(Value, '| <a class="tn15more inline" href="synopsis">', '</a>'), '');
    Value := StringReplace(Value, Textbetween(Value, '<a class="tn15more inline" href="synopsis">', '</a>'), '');
    Value := StringReplace(Value, '| <a class="tn15more inline" href="synopsis"></a>', '');
    Value := StringReplace(Value, '<a class="tn15more inline" href="synopsis"></a>', '');
    Value := StringReplace(Value, '»', '');
    if (Value = #13#10 + #13#10) or (Value = #13#10) then
      Value := '';
    if (GetOption('DescriptionSelection') = 0) and (Pos('<a class="tn15more inline"', Value) > 0) then
      Value := TextAfter(Value, #13#10);
    if Value <> '' then
      SetField(fieldDescription, ImportSummary(Value));
  // Length
    Value := TextBetween(PageText, '<h5>Runtime:</h5>', '</div>');
    Value := TextBefore(Value, ' min', '');
    if Value <> '' then
      if Pos(':', Value) > 0 then
        SetField(fieldLength, TextAfter(Value, ':'))
        SetField(fieldLength, Value);
  // Producer
    Value := TextBetween(PageText, 'Produced by</a></h5>', '</table>');
    FullValue := '';
    SetField(fieldProducer, FullValue);
  // Writer
  if CanSetField(fieldWriter) then
    Value := TextBetween(PageText, 'Writing credits</a></h5>', '</table>');
    FullValue := '';
    SetField(fieldWriter, FullValue);
  // AKA Name
    FullValue := ConvertToASCII(GetPage(MovieURL+'/releaseinfo#akas'));
    FullValue := TextBetween(FullValue, '<a id="akas" name="akas">', '</table>');
    FullValue := RemoveSpaces(FullValue, True);
    FullValue := StringReplace(FullValue, #13, '');
    FullValue := StringReplace(FullValue, #10, '');
    FullValue := StringReplace(FullValue, '<tr class="even">', '<tr>');
    FullValue := StringReplace(FullValue, '<tr class="odd">', '<tr>');
    if RegExprSetExec('</td>\s*<tr>', FullValue) then
      // removing the original title
      FullValue := '<tr>'+TextAfter(FullValue, '</td><tr>');
    while fullvalue <> '' do
  //   showMessage('Analysing: '+FullValue);
    // each line is a pair of  translated title and country
    // format: <tr><td>country</td><td>Translated title</td><tr>
      value2 := TextBetween(FullValue, '<tr>', '</tr>');
    // showMessage('Line: '+value2);
      value := TextBetween(Value2, '<td>', '</td>');
      value2 := TextAfter(Value2, '</td>');
      value2 := TextBetween(Value2, '<td>', '</td>');
      HTMLDecode(value2);
   //  showMessage('Translated: '+value+' into '+value2);
      if pos(UserCountry, value) > 0 then
        HTMLDecode(Value2);
        SetField(fieldTranslatedTitle, FullTrim(UTF8Decode(Value2)));
        FullValue := '';
      else  FullValue := TextAfter(FullValue, '</tr>');
    if Value <> '' then
      Value := StringReplace(Value, 'See more', '');
      Value := FullTrim(StringReplace(Value, '<br>', ', '));
      HTMLDecode(Value);
      if Value <> '' then
        if StrGet(Value, Length(Value)) = ',' then
          Delete(Value, Length(Value), 1);
      SetField(fieldTranslatedTitle, Value)
  // Comments
    if (GetOption('CommentType') = 1) then
      //Value := TextAfter(PageText,'/rg/title-nav-item/usercomments/');
      //if (Value <> '') or (Pos('href="usercomments" class="link"', PageText) > 0) then
        Value2 := '';
        FullValue := ConvertToASCII(GetPage(MovieURL+'/usercomments'));
        FullValue := TextAfter(FullValue, 'review useful:</small><br>');
        while FullValue <> '' do
          Value := TextBetween(FullValue, '<b>', '<div');
          //Value2 := Value2 + #13#10 + #13#10 + TextBefore(Value, '</b>', '');
          Value2 := Value2 + #13#10 + #13#10 + TextBetween(Value, '">', '</a>');
          Value2 := Value2 + #32+ TextBetween(Value, '<small>', '</small>');
          Value2 := Value2 + #32 + 'said on ' + TextBetween(Value, '<small>', '</small>');
          Value := TextBetween(Value, 'comments">', '<br>');
          HtmlRemoveTags(Value);
          Value2 := Value2 + #13#10 + Value;
          Value := TextBetween(Value, '<p>' + #13#10, #13#10 + '</p>');
          Value := StringReplace(Value, #13#10, ' ');
          Value := StringReplace(Value, '<br><br>', #13#10);
          HtmlDecode(Value);
          Value2 := Value2 + #13#10 + FullTrim(Value);
        HTMLDecode(Value2);
        SetField(fieldComments, 'USER COMMENTS:' + Value2 + #13#10);
    if (GetOption('CommentType') = 0) then
      Value := TextAfter(PageText, '/comments">');
      if Value <> '' then
        HTMLDecode(Value);
        while Pos('  ', Value) > 0 do
        while Pos(#13#10, Value) = 1 do
          Delete(Value, 1, 2);
    if (GetOption('CommentType') = 2) then
      SetField(fieldComments, '');
  // TagLine
  if GetOption('GetTagline') > 0 then
    Value := TextBetween(PageText, '<h5>Tagline:</h5>', '</div>');
    if Pos('<a', Value) > 0 then
      Value := TextBefore(Value, '<a', '');
    HTMLDecode(Value);
    if Value <> '' then
      if StrGet(Value, 1) <> '"' then
        Value := '"' + Value + '"';
      case GetOption('GetTagline') of
        1:
            if GetField(fieldDescription) <> '' then
              Value := Value + #13#10 + #13#10 + GetField(fieldDescription);
        2:
            if GetField(fieldComments) <> '' then
              Value := Value + #13#10 + #13#10 + GetField(fieldComments);
  // Trivia
  if GetOption('Trivia') > 0 then
    sleep(50);
    Value := MovieUrl;
    FullValue := ConvertToASCII(GetPage(Value+'/trivia'));
    case GetOption('Trivia') of
      1,2:
        Value := TextBetween(FullValue, '<div class="sodatext">', '</div>');
      3,4:
        Value := TextBetween(FullValue, '<div class="list">', '<div id="sidebar">');
    if Value <> '' then
      Value := StringReplace(Value, #13#10, '');
        Value := StringReplace(Value, '  ', '');
      while Pos('<span class="linksoda">', Value) > 0 do
        Value := StringReplace(Value, TextBetween(Value, '<span class="linksoda">', '</div>'), '');
        Value := StringReplace(Value, '<span class="linksoda"></div>', '');
      Value := StringReplace(Value, 'Link this trivia', '');
      Value := StringReplace(Value, '<div class="sodatext">', #13#10 + '- ');
      Value := StringReplace(Value, TextBetween(Value, '<script type="text/javascript">', '</script>'), '');
      HTMLDecode(Value);
      Value := RegExprSetReplace('\s[\d,]+\s+of\s+[\d,]+\sfound\sthis\sinterestingInteresting\?YesNo\|', Value, '', false);
      Value := RegExprSetReplace('\s*Is\sthis\sinteresting\?Interesting\?YesNo\|', Value, '', false);
      Value := RegExprSetReplace('Spoilers\sThe\strivia\sitems?\sbelow\smay\sgive\saway\simportant\splot\spoints\.\s*', Value, #13#10 + 'Spoilers:' + #13#10, false);
      Value := RegExprSetReplace('\s*See\salsoGoofs.*', Value, '', false);
      if (GetOption('Trivia') = 1) or (GetOption('Trivia') = 2) then
        Value := ' ' + Value;
        1,3:
              Value := GetField(fieldDescription) + #13#10 + #13#10 + 'IMDB TRIVIA:' + Trim(Value)
              Value :=  'IMDB TRIVIA: ' + Value;
        2,4:
              Value := GetField(fieldComments) + #13#10 + #13#10 + 'IMDB TRIVIA:' + Trim(Value)
  // Awards
  if (GetOption('Awards') > 0) then
    ImportAwards();
  // Rating
//   (Remove the "//" of the next two lines beginning with "Value" and add "//" to the following two lines beginning with Value
//   if you would like to import arithmetic ratings instead of IMDB's user ratings)
//    Value := ConvertToASCII(GetPage(MovieURL + '/ratings'));
//    Value := TextBetween(Value, 'Arithmetic mean = ', '. ');
    Value := TextBetween(PageText, '<h5>User Rating:</h5>', '</b>');
    Value := TextBetween(Value, '<b>', '/');
    if Value <> '' then
      if (GetOption('RoundRating') = 1) then
        SetField(fieldRating, IntToStr(Round(StrToFloat(Value))))
        SetField(fieldRating, Value);
  if GetOption('UserRatings') > 0 then
      Value := TextBetween(PageText, '<a href="ratings" class="tn15more">', '</a>');
      if Value <> '' then
        Value := 'User Rating: ' + GetField(fieldRating) + ' out of 10  (with ' + Value + ')';
      if (GetOption('UserRatings') = 1) and (Value <> '') and (CanSetField(fieldMediaType)) then
      if (GetOption('UserRatings') = 2) and (Value <> '') then
        SetField(fieldComments, GetField(fieldComments) + #13#10 + #13#10 + Value);
  // Classification
  if CanSetField(fieldCertification) then
    if UserCountry = '' then
      ShowMessage('Country not set for classification selection - Click "Editor" tab in the scripting window, then select your country by modifying the required line as explained in the first lines of the code')
      Value := TextBetween(PageText, '<a href="/search/title?certificates=', '</div>');
      Value := TextBetween(Value, UserCountry + ':', '</a>');
      if Value <> '' then
        SetField(fieldCertification, Value);
  // MPAA rating
  if (GetOption('MPAA') > 0) then
     Value := FullTrim(TextBetween(PageText, '<h5><a href="/mpaa">MPAA</a>:</h5>', '</div>'));
     // Value := TextAfter(Value, #13#10);
     if Value <> '' then
      if GetOption('MPAA') = 1 then
        SetField(fieldMediaType, TextBetween(Value, 'Rated ', ' '))
// ***** Imports lists like Genre, Country, etc. depending of the selected option *****
function ImportList(PageText: string; MultipleValues: Integer; StartTag: string): string;
  Value, Value2: string;
  if MultipleValues = 0 then
    Value := TextBetween(PageText, StartTag, '</a>');
    Value2 := TextAfter(Value, '">');
    Value := TextBetween(PageText, StartTag, '</div>');
    Value2 := TextBefore(Value, '<a class="tn15more inline"', '');
    if Value2 = '' then
      Value2 := Value;
    if MultipleValues = 1 then
      Value2 := StringReplace(Value2, ' | ', ', ');
    if MultipleValues = 2 then
      Value2 := StringReplace(Value2, ' | ', ' / ');
    if MultipleValues = 3 then
      Value2 := '';
  Value2 := StringReplace(Value2, #13#10, '');
  Value2 := StringReplace(Value2, ' , ', ', ');
  HTMLDecode(Value2);
  Result := FullTrim(Value2);
// ***** functions to import the different pictures kinds, depending of the option selected by user *****
//Import small picture from IMDB movie main page
function ImportSmallPicture(PageText: string): Boolean;
  Value: string;
  Result := False;
  Value := TextBetween(PageText, '<div class="photo">', '</div>');
  if (Value <> '') and (Pos('"Poster Not Submitted"', Value) = 0) then
    Value := TextBetween(Value, 'src="', '"');
    if Value <> '' then
      Value := StringReplace(Value, 'https://images-na.ssl-images-', 'http://images.');
      GetPicture(Value);
      Result := True;
//Import large image from link on IMDB movie main page
function ImportLargePicture(PageText: string): Boolean;
  Value: string;
  Result := False;
  if (Value <> '') and (Pos('"Poster Not Submitted"', Value) = 0) and (Pos('<a name="poster" href="/rg/action-box-title/primary-photo', Value) > 0) then
    Value := TextBetween(Value, 'href="/rg/action-box-title/primary-photo', '"');
    if Value <> '' then
      Value := 'http://www.imdb.com' + Value;
      Value := GetPage(Value);
      Value := TextBetween(Value, 'primary-img', '</div>');
      if (Value <> '') and (Pos(' src="', Value) > 0) then
        Value := TextBetween(Value, ' src="', '"');
        GetPicture(Value);
        Result := True;
//Image not available, import "No Poster Available" icon
function ImportPictureNotAvailable(PageText: string): Boolean;
  Value: string;
  Result := False;
  if (Value <> '') and (Pos('"Poster Not Submitted"', Value) > 0) then
    if Value <> '' then
      GetPicture(Value);
      Result := True;
//Image from DVD Details Page
function ImportDvdDetailsPicture: Boolean;
  Value, PageText: string;
  Result := False;
  PageText := ConvertToASCII(GetPage(MovieUrl+'/dvd'));
  Value := TextBefore(PageText, '.jpg alt="', '<table class="dvd_section" cellpadding="10"><tr>');
  if Value <> '' then
    Value := TextBetween(Value, '<a href="', '">');
    if Value <> '' then
      Result := ImportFromAmazonRedirect('http://www.imdb.com' + Value);
//Image from Merchandising Links (/sales) Page
function ImportMerchandisingPicture: Boolean;
  Result := False;
  PageText := ConvertToASCII(GetPage(MovieUrl+'/sales'));
  Value := TextBefore(PageText, '.jpg" width=', '<td class=w_rowtable_colcover><a href="');
  if Value <> '' then
    Value := TextBefore(Value, '"><img', '');
    if Value <> '' then
function ImportFromAmazonRedirect(Url: string): Boolean;
  Result := False;
  PageText := ConvertToASCII(GetPage(Url));
  Value := TextBetween(PageText, '<td id="prodImageCell"', '" id="prodImage"');
//  Value := StringReplace(TextAfter(Value, ' src="'), '_AA240', '');
  Value := StringReplace(Value, TextBetween(Value, '_AA', '_'), '');
  Value := StringReplace(TextAfter(Value, ' src="'), '_AA', '');
  if Value <> '' then
    GetPicture(Value);
    Result := True;
// ***** Gets summaries for the movie, based on the plot outline given in parameter (that contains the URL to more summaries) *****
function ImportSummary(PlotText: string): string;
  Address, Value, Value2, Value3, Value4, PageText, Longest: string;
  Address := TextBetween(PlotText, '<a class="tn15more inline" href="', '" ');
  if (Address = '') or (GetOption('DescriptionSelection') = 0) or (GetOption('DescriptionSelection') = 3) then
    Value3 := FullTrim(TextBefore(PlotText, '<a class="tn15more inline"', ''));
    if Value3 = '' then
      Value3 := FullTrim(PlotText);
    HTMLRemoveTags(Value3);
    HTMLDecode(Value3);
  if (Address <> '') and (GetOption('DescriptionSelection') > 0) then
    PageText := ConvertToASCII(GetPage('http://www.imdb.com' + Address));
    PickListClear;
    Longest := '';
    //Value := TextBetween(PageText, '<p class="plotpar">', '</p>');
    Value := TextBetween(PageText, '<p class="plotSummary">', '</p>');
      //Value := TextBefore(Value, '<i>', '');
      Value := FullTrim(StringReplace(Value, #13#10, ' '));
      HTMLDecode(Value);
      if Length(Value) > Length(Longest) then
        Longest := Value;
      PickListAdd(FullTrim(Value));
    if (GetOption('BatchMode') > 0) or (GetOption('DescriptionSelection') = 2) then
      Value4 := Longest
      if not PickListExec('Select a description for "' + GetField(fieldOriginalTitle) + '"', Value4) then
        Value4 := '';
  if Value3 <> '' then
     if Value4 <> '' then
        Result := Value3 + #13#10 + #13#10 + Value4;
        Result := Value3;
     Result := Value4;
// Import awards
procedure ImportAwards;
  IndexPage: TStringList;
  PageText, FullValue, Block, Value, Row, Outcome, Details, AwardShow, PageText1: string;
  Year, Result, Award, Category: string;
  sleep(50);
  Value := MovieUrl;
  PageText := ConvertToASCII(GetPage(Value+'/awards'));
    AwardShow := TextBetween(PageText, '<h3>', '</h3>');
    if Pos('User Lists', AwardShow) > 0 then
      break;
      HTMLRemoveTags(AwardShow);
      HTMLDecode(AwardShow);
      AwardShow := FullTrim(AwardShow);
      AwardShow := StringReplace(AwardShow, #13, '');
      AwardShow := StringReplace(AwardShow, #10, '');
      FullValue := FullValue + #32 + AwardShow + #13#10;
      PageText1 := TextBetween(PageText, '<table class="awards"', '</table>');
      Block := PageText1;
        Row := TextBetween(Block, '<tr>', '</tr>');
        Block := RemainingText;
        Outcome := TextBetween(Row, '<b>', '</b>');
        Category := TextBetween(Row, '<span class="award_category">', '</span>');
        Award := TextBetween(Row, '<td class="award_description">', '</td>');
        Details := TextBetween(Row, '<div class="award_detail_notes">', '</div>');
        If Outcome <> '' then
          FullValue := FullValue + #32 + Outcome + #13#10;
        If Category <> '' then
          FullValue := FullValue + #32 + Category;
        If Award <> '' then
          Award := StringReplace(Award, '<br />', #32);
          HTMLRemoveTags(Award);
          HTMLDecode(Award);
          Award := StringReplace(Award, #13, '');
          Award := StringReplace(Award, #10, '');
          Award := FullTrim(Award);
          Award := StringReplace(Award, '  ', '');
          FullValue := FullValue + #32 + Award;
        If Details <> '' then
          HTMLRemoveTags(Details);
          HTMLDecode(Details);
          Award := StringReplace(Details, #13, '');
          Award := StringReplace(Details, #10, '');
          Award := FullTrim(Details);
          FullValue := FullValue + #32 + Details + #13#10;
     until (Row = '');
  until (PageText1 = '');
 // ShowInformation(FullValue);
    case GetOption('Awards') of
      1:
            Value := GetField(fieldDescription) + #13#10 + #13#10 + 'AWARDS: ' + #13#10 + FullValue
            Value := 'AWARDS: ' + FullValue;
      2:
            Value := GetField(fieldComments) + #13#10 + #13#10 + 'AWARDS: ' + #13#10 + FullValue
// ***** beginning of the program *****
      if ShowWarning('Old version of file "Stringutils1.pas" detected: v'+IntToStr(StringUtils1_Version)+#13#10+'The script requires at least version 7.'+#13#10+'Download and install latest version now ?') = True then
          UpdateFile.Text := GetPage('http://update.antp.be/amc/scripts/StringUtils1.pas');
          UpdateFile.Free;
          ShowInformation('StringUtils1 has been updated. Please restart IMDB script now. Thank you.');
          Exit;
          ShowInformation('You can download latest version of "StringUtils1.pas" using script "update scripts" or via http://update.antp.be/amc/scripts');
          Exit;
  // Check for current AMC version
  if CheckVersion(4,2,0) then
    MovieYear := GetField(fieldYear);
    MovieName := '';
    if GetOption('BatchMode') = 2 then
      MovieName := GetField(fieldURL);
      if Pos('imdb.com', MovieName) = 0 then
        MovieName := '';
      if not Input('IMDB Import', 'Enter the title or the IMDB URL of the movie:', MovieName) then
        Exit;
      Sleep(500);
    if MovieName <> '' then
      if Pos('imdb.com', MovieName) > 0 then
        AnalyzeResultsPage(MovieName)
      else if RegExprSetExec('tt[0-9]+', moviename) then
        AnalyzeResultsPage('http://www.imdb.com/title/' + MovieName)
        MovieName := UTF8Encode(StringReplace(MovieName, '&', 'and'));
        if (GetOption('BatchMode') > 0) or (GetOption('PopularSearches') = 1) then
          AnalyzeResultsPage(PopularTitleSearchURL + UrlEncode(MovieName))
          AnalyzeResultsPage(FullTitleSearchURL + UrlEncode(MovieName));
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 4.2)');
Interesting suggestion, thanks.
I uploaded it to the server as official script version 3.88
