Show old values in Results windows
bmm
Post by bmm »
It would be nice if old values could be shown in a 3rd column in the results window after running a script. This way it would be possible to check which values is replaced (without moving the results window to see the normal window behind).
A check-box for imported pictures in the result windows would also be nice if this is possible since it isn't an ordinary field.
Yes I should do that... I'll put it on my to-do list...
