I'm trying to add parenthesis around the year in a folder full of movies that also have other numbers in the title or type.
For example, if I have the following two movies:
Good Movie 2008 [1080p BluRay].mp4
1984 1984 [1080p BluRay].mp4
I want to rename them to:
Good Movie (2008) [1080p BluRay].mp4
1984 (1984) [1080p BluRay].mp4
I've been working with the following regular expression, but it add parenthesis around the 1080 rather than the year.
Expression: ^(.*)([0-9]{4})(.+)$
New Name: $1($2)$3
Any help would be greatly appreciated.
Add Parenthesis Around Year in Title with Multiple Numbers
mjschulz
You may prefix the expression by (?-g) to make groups work in non-greedy mode, i.e. they'll take less possible instead of most possible.
It seems to work in this particular example, check if that can applied to all your title cases.
So:
(?-g)^(.*)([0-9]{4})(.+)$
or
^((?-g).+)([0-9]{4})(.+)$
if you only want to apply that to the first group (in case it cause other problems in more complex expressions)
So:
or
