How do I stop ant renamer from renaming my directories??
kbdrand
Recently when I upgraded the ant renamer software, now it always renames my current directory when it is renaming files. I do not want it to rename the directory. How do I stop that?
You probably at some point enabled the "add selected folders" option when adding files via the "add folders" button or via drag & drop.
In the first case, simply uncheck that option when adding files, in case it is by drag & drop and that you checked "do not ask again", you can change that option in the Preferences window (tab "Files & folders").
