nfo & location
Prophet
nfo & location
Post by Prophet »
can you make it so we can store .nfo files in the next version?
also a location thing would be nice
like Spindle 1 or Binder C or C:\My Stuff\ etc etc
What do you mean by storing NFO ? Put the NFO in the catalog ?
You can put e.g. in Comments field.
For the location, you can also use one of the field that you do not use ;)
Next version should allow to customize/define fields ;)
Prophet
Post by Prophet »
ahhh
ok, never thought of that
thanks^^
