hello i have 2 catalog : one for movies and the other for ebooks
the probleme is that both dont have the same system management:
- movies are sortes by number of dvd and using list view
- ebooks are sorted by writer name and years of book and title and unsing thumbnails
but when i move from one catalog to another i have to change settinf from the begining
so my suggestion is to have the personlized setting saved on the movies files so we can have more than catalog each one is with his own personalisation
PS: an old suggestion still up to date is to make software supporting utf-8 cause we hate the applocal inteface ....
personalization of sorting & view
You can have different settings files.
Make one shortcut per use, and add the /prefs params to specify which settings has to be used with which catalog instead of the default prefs.xml
moviecatalog.exe "c:\users\you\documents\catalogs\books.amc" /prefs "c:\programdata\ant movie catalog\prefsbooks.xml"
Adding unicode support, that's a lot of work, and I doubt that soulsnake will have time for that (I know that for myself I don't...)
zdig1
