[REL][EN] DVD Empire updated script
deadeye
Post by deadeye »
Script update with the following changes:
* Better picture retrieval
* Fixed error when getting movie by URL
* Fixed error when large number of results returned
Authors=dmitry501,Pavel Uher,Chetan Rao,Deadeye
Title=DVDEmpire.com
Description=Import script for DVD Empire
Site=http://www.dvdempire.com
Language=EN
Version=2.2.5
Requires=4.1.0
Comments=
RequiresMovies=1
MediaType=0|0|0=All Products|1=DVD|2=Blu-ray
PictureType=1|1|0=Large Picture|1=Small Picture
ClearCheckMark=1|1|0=No|1=Yes
[Parameters]
program DVDEmpire;
  StringUtils1;
  LF = #13#10;
  MovieName: String;
  MediaType: String;
  UpdateFile: TStringList;
// ********** Get multiple values from a string **********
// ********** Returns string with comma or linefeed between each item **********
function GetMultiValues(Line : String; StartTag : String; EndTag : String; UseCommaDelimiter : Boolean): String;
  Value     : String;
  Delimiter : String;
  Result := '';
  if (UseCommaDelimiter) then
    Delimiter := ', '
    Delimiter := LF;
  while(true) do
    Value := TextBetween(Line, StartTag, EndTag);
    if Value = '' then
      break
      HTMLDecode(Value);
      HTMLRemoveTags(Value);
      if Pos(Value, Result) = 0 then     // if not a duplicate
        if (Length(Result) > 0) then
          Result := Result + Delimiter;
        Result := Result + Value;
      Line := RemainingText;
// ********** Gets the specific movie info **********
procedure GetMovieInfo(Address: String);
  PageText, Value, TempValue: String;
  hours, mins: Integer;
  PageText := GetPage(Address);
  // URL
  // Picture
  Value := TextBetween(PageText, '<link rel=''image_src'' href="', '" />');
  if GetOption('PictureType') = 1 then
    Value := StringReplace(Value, 'h.jpg', 'm.jpg');
  GetPicture(Value);
  // Original Title
  Value := FullTrim(TextBetween(PageText, 'START Title --><h1>', '</h1>'));
  // Media Type
  Value := FullTrim(TextBetween(PageText, 'spacing-bottom"><h2 class="border-bottom-default">', '<div class="hover'));
  // Description
  Value := TextBetween(PageText, 'spacing-bottom text-dark synopsis">', '</h4>');
  Value := StringReplace(Value, '</p><p>', LF);
  Value := StringReplace(Value, '®', '®');
  HTMLDecode(Value);
  Value := FullTrim(Value);
  // Length
  Value := TextBetween(PageText, 'datetime="PT', 'M');
  SetField(fieldLength, Value);
  // Rating
  Value := 'Rating: ' + Trim(TextBetween(PageText, '<span itemprop="contentRating"> ', '</span>'));
  // Year
  Value := FullTrim(TextBetween(PageText, 'Production Year</strong>', '</li>'));
  SetField(fieldYear, Value);
  // Number of Discs
  Value := FullTrim(TextBetween(PageText, 'Number of Discs</strong>', '</li>'));
  SetField(fieldDisks, Value);
  // Subtitles
  Value := FullTrim(TextBetween(PageText, 'Subtitles</strong>', '</li>'));
  SetField(fieldSubtitles, Value);
  // Video format
  Value := FullTrim(TextBetween(PageText, 'Video</strong><br />', '</li>'));
  Value := RemoveSpaces(Value, true);
  Value := StringReplace(Value, '<br />', ' ');
  SetField(fieldVideoFormat, Value);
  // Audio
  TempValue := FullTrim(TextBetween(PageText, 'Audio</strong><br />', '</li>'));
  if TempValue <> '' then
    TempValue := RemoveSpaces(TempValue, true);
    Value := TextBetween(TempValue, ' ', '<br />');
    SetField(fieldAudioFormat, Value);
    // Languages
    Value := '<br />' + TempValue;
    Value := GetMultiValues(Value, '<br />', ' ', true);
  // Actors
  Value := FullTrim(TextBetween(PageText, 'Cast</h2>', '</ul>'));
  Value := GetMultiValues(Value, '">', '</a>', false);
  SetField(fieldActors, Value);
  // Producer(s)
  Value := FullTrim(TextBetween(PageText, 'Production</h2>', '</ul>'));
  Value := GetMultiValues(Value, '<span itemprop="name">', '</span>', true);
  // Director(s)
  Value := FullTrim(TextBetween(PageText, 'Director</h2>', '</ul>'));
  Value := GetMultiValues(Value, '">', '</a>', true);
  // Clear Check Mark
  if GetOption('ClearCheckMark') = 1 then
    SetField(fieldChecked, 'false');
// ********** Gets the movie titles/addresses from the search results page **********
  LineNr, L: Integer;
  SCount: String;
  PageText, MovieText: String;
  MovieAddress, MovieTitle, MovieYear: String;
  SCount := TextBetween(PageText, '<span class="matches-found"><strong>', '</strong> Matches Found');
  SCount := StringReplace(SCount, ',', '');
  L := StrToInt(SCount,1);
  PageText := RemainingText;
  if L > 0 then
    if L > 50 then
      PickTreeAdd('First 50 results of ' + IntToStr(L), '');
      L := 50;
      PickTreeAdd(IntToStr(L)+' Matches found', '');
      // Get the info of one result
      MovieText := TextBetween(PageText, '<h3><small>', '<ul class="item-details spacing-bottom-alt">');
      // find the link
      MovieAddress := 'http://www.dvdempire.com' + TextBetween(MovieText, '<a href="', '"');
      MovieText := RemainingText;
      // find the movie name
      MovieTitle := TextBetween(MovieText, 'title="', '"');
      // find the year
      MovieYear := FullTrim(TextBetween(MovieText, ' <small>(', ')</small>'));    // movie release year
      if MovieYear <> '' then
        MovieTitle := MovieTitle + ' [' + MovieYear + ']';
      // add it to the tree
      HTMLDecode(MovieTitle);
      HTMLRemoveTags(MovieTitle);
      // decrement counter
      L := L - 1;
    until L = 0;
    GetMovieInfo(Address);
// ********** Begin program **********
    if ShowWarning('Old version of file "Stringutils1.pas" detected: v' + IntToStr(StringUtils1_Version) + LF + 'The script requires at least version 7.' + LF + 'Download and install latest version now ?') = True then
      UpdateFile.Text := GetPage('http://update.antp.be/amc/scripts/StringUtils1.pas');
      UpdateFile.Free;
      ShowInformation('StringUtils1 has been updated. Please restart the DVD Empire script now. Thank you.');
      Exit;
      ShowInformation('You can download latest version of "StringUtils1.pas" using script "update scripts" or via http://update.antp.be/amc/scripts');
      Exit;
  // Check for current AMC version
  if CheckVersion(4,1,0) then
    PickListClear;
    if not Input('Import from DVD Empire', 'Enter the title or the URL of the movie:', MovieName) then
      Exit;
    if Pos('dvdempire.com', MovieName) > 0 then
      GetMovieInfo(MovieName);
      Exit;
      MovieName := AnsiLowerCase(MovieName);
      MovieName := StringReplace(MovieName, '’', '');
      MovieName := StringReplace(MovieName, Chr(39), '');
      MovieName := StringReplace(MovieName, ' ', '+');
      MovieName := StringReplace(MovieName, '&', '%26');
      MovieName := StringReplace(MovieName, ':', '%3A');
      MediaType := 'allsearch';
      // DVD
      if GetOption('MediaType')=1 then MediaType := 'dvd';
      // Blu-ray
      if GetOption('MediaType')=2 then MediaType := 'blu-ray';
      AnalyzePage('http://www.dvdempire.com/' + MediaType + '/search?exactMatch=' + MovieName + '&q=' + MovieName + '&sort=score&pageSize=50');
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least version 4.1.0)');
Thanks!
