Using group numbers in replace
JonF
Post by JonF »
I have gobs and gobs of files named like "Fred Bear.pst". I want to rename those to "FBear@red.com.pst", where the "red.com.pst" part is constant. So I selected "String Replacement" and wrote a regex:
^(.)(\S*) ([a-z]*)
And a replacement string:
$1$3@red.com.pst
But this does nothing. "Old name is the same as the new name". What am I missing?
You should use [A-Za-z], expressions are case-sensitive
And the next name should not include the extension since here it will stop at the "." (as there is no $ at the end, and the "." is not grabbed by the a-z range)
