trimming the end of a file
wolfkin
Post by wolfkin »
I would like to trim the end of a file name.
So for instance:
This is what I have so far
Find: \[\w+].(jpg|png|gif|bmp)$
Replace: .$1
but I'm not sure how to make it work for folders like
EastofEden[Scan]
There is maybe a cleaner way to do it, but this seems to work:
^(.+)\[\w+](\.(jpg|png|gif|bmp))?$
$1$2
