Convert .xml to .AMC?
Capndad
Post by Capndad »
My hard drive crashed, and for the life of me I cannot find a backup of the .amc backup file.
So first of all, is .amc the right extension I'm looking for? I assume so.
Secondly, I did find the movies in an XML file, but how do I get AMC to use that correctly? I converted it to .csv and then imported that, but not what I wanted.
Cheers,
Cap :)
If that was a .xml generated by AMC normally you can open it directly with AMC: the catalog can be stored either in .xml or .amc
With the .amc images can be either directly in it, or as external files; with .xml images are always external files.
