Automatically batch get information from Internet
band
Post by band »
Hi there
Is there a way to automatically batch "get information from Internet" via "IMDB IMPORT" , that it does not need to "Enter the title or .." and "Movie Selection",
And AMC itself select the highlighted name from "Original Title" for search and select first movie in the "movie selection" as desired Movie?
So I can Update and get information for all catalog movies without interruption.
Thank you
If you select multiple movies before calling the "get information via script", the script will be run on these movies.
Some scripts have special batch options (which is the case of IMDB) : on the right of the scripts list, there are options for selected script.
band
Post by band »
Thank you
I use it in the "IMDB", and it works perfectly.
My another request is a batch mode for the "All Movie Guide" script, in the way that, it does not need me to select the movie from the list, and the first movie in the list be selected automatically, like the BatchMode=1 and 2 in the "IMDB" script. So I can import the big pictures from this site for the multiple selected movies automatically without any prompt.
ZuperMario
Re: Automatically batch get information from Internet
Post by ZuperMario »
Hello,
i resume this old post because i'm trying several (italian) script but all ask me to confirm the movie name. There isn't a batch mode to avoid to confirm every single movie name? Thanks.
Pr capire se esiste tale opportunità devi valutare le opzioni disponibili per lo script che esegui e/o leggere i suggerimenti relativi allo script stesso (linguetta "commenti" in basso nell videata di esecuzione).
davezn
Post by davezn »
Hi Admin.
I have just added 600 Movies into my Catalouge. I now need to update the movie information for the 600 movies.
Is there anyway of updating these movies without having to sit and select each movie 1 at a time?
This would be a BIG time saver for me.
Regards and Happy Easter :)
David
cf messages above: it depends if the script that you have has an option for batch import
davezn
Post by davezn »
Thank you, figured it out from Batch Mode 1 and 2, this is perfect, makes life at lot easier. Happy Easter.
davezn wrote: 2018-04-01 09:28:54 Thank you, figured it out from Batch Mode 1 and 2, this is perfect, makes life at lot easier. Happy Easter.
Which script did you use? you never told.
Happy easter.
davezn
Post by davezn »
Hi, sorry I am using 2 at the moment, tested on 4 Movies, was perfect now running on the other 600. :)
davezn
Post by davezn »
Morning,
Ran the Batch Script 1.
95% succesful.
Errors due to incorrect spelling or year, that was my fault.
One important thing is to make sure when selecting batch mode 1 or 2, is to make sure that in EXECUTION OPTIONS THAT "show results window is UNCHECKED".
Kind Regards
DAVEZN
z3us
Post by z3us »
Is it possible to search the info from internet using the file name ?
z3us wrote: 2020-01-28 11:15:21 Is it possible to search the info from internet using the file name ?
First of all:
- which script do you want to use? :ha:
after:
will you give an example of "file name"? :??:
