import all data using the actual imdb URL?
KnightRid
Post by KnightRid »
Hi, I was wondering if there is a way to do a batch update to an entire list of movies using the IMDB URL field rather than the name?
I have a CSV file that includes the name, video format, # of discs, and imdb url. I can import it no problem, but i cant seem to find anything that will use the url to grab the pic ( best quality possible, amazon? ) and the other fields.
I would appreciate it if someone could tell me then ame of the template that would do this, or a description on how I could try and edit the imdb batch import to do this - PLEASE respond in NON-PROGRAMMING terms :) I am not even close to being able to program :cry:
VERY nice program also!! As long as I can do this batch update like I want - I will be VERY happy!!!!!!!
Thank You
It is actually easy to do.
e.g. with the "IMDB (batch)" script :
At the end of the script, you find this block:
  if CheckVersion(3,4,0) then
    if MovieName <> '' then
//      AnalyzePage('http://us.imdb.com/Tsearch?title='+UrlEncode(MovieName)+'&restrict=Movies+only');
      AnalyzePage('http://us.imdb.com/Tsearch?title='+UrlEncode(MovieName));
(or something that is very similar)
Replace it with this :
    AnalyzePage(GetField(fieldURL));
It should work.
Just select several movies then go to Tools -> Scripting to apply the script to these movies.
KnightRid
Post by KnightRid »
oh you rule!!! THANK YOU!!
Knight Rider
ok, great, now how about checking for url first, then, if not found, it checks the name?
you mean if url is empty ?
  if GetField(fieldURL) = '' then
