AMCReport not working in Windows 10?
MDFanatik
Post by MDFanatik »
I was wondering if anyone is using AMCReport (to create a printtemplate) in windows 10. After moving to windows 10 I can't seem to get it to work. I'm using version 1.9.0.1 Are there any dependencies (net 2.0 / net 3.5) that I should install? Many thanks for helping me!
Version 4.2.0.2 works, but AMC 4.2.1 [BETA] not. I'm gonna post this also in that thread!
Normally there aren't any dependencies.
What is the problem that you encounter?
I tested installing 4.2.0 then upgrading to 4.2.1 beta on the Windows 10 I have here, and it seems to open and display fine.
I haven't yet applied the latest update of Windows 10 though (1511).
I just did a short test on W10Pro with 1511 update (Windows upgraded from 8.1Pro) and did not see any problems also, using AMC 4.2.1.1 beta with AMCReport 1.9.0.1. there.
MDFanatik
Post by MDFanatik »
bad4u wrote:I just did a short test on W10Pro with 1511 update (Windows upgraded from 8.1Pro) and did not see any problems also, using AMC 4.2.1.1 beta with AMCReport 1.9.0.1. there.
Just tried it again and now it works. It looked like it had something to do with Avast virusscanner. Thank you all for replying!
