Script for export to Kodi ( 15.x tested)
Harald
Post by Harald »
What does this script:
Exports data to simple xml as filename.nfo for use in Kodi.
Exports Picture to filename-poster.ext for use in Kodi.
* filename comes from filed [FilePath].
if [FilePath] is empty then field [OriginalTitle] is used
and you'll be asked to enter a existing folder name to export to.
Folder must already exist.
If file not created , then foldername was not correct or not existing.
before import in Kodi make sure files match same name.
example: Superman.nfo
Superman.mkv
Best way to use:
1 create new ant catalog.
2 use File-->import-->Media Files then field [FilePath] will exist.
3 add your data with ant-scripts by pressing F6.
4 press SHIFT-F6 and choose the AMC_to_Simple_Kodi script.
Succesfully tested for Kodi 15.x
script is based on AMC_to_XBMC_xml_Export.ifs thanks to 'dowiew' the author.(hope you did not mind) .
Hope you like it.
save all in code to : AMC_to_Simple_Kodi.ifs in the AMC-script folder.
Authors=Harald
Title=AMC to Simple Kodi xml Export
Description=Export movie data  to  movie.nfo and Picture to movie-poster.jpg if FilePath exists in movie data else save to OriginalTitle.nfo and OriginalTitle-poster.ext asked folder
Site=
Language=EN
Version=1.0
Requires=3.5.0
Comments=Read source code comments!
GetInfo=0
RequiresMovies=1
[Parameters]
program AMCtoSimpleKodiXMLExport;
  sx: string;
  sl: TStringList;
  SFileName, SaveFileName, MovieNumber, XBOX_Movies_Path: string;
  i:integer;
procedure Ask(Msg: string; var TheStr: string);
  if not Input('AMC to Simple Kodi xml Export', Msg, TheStr) then TheStr:='';
  sl := TStringList.Create;
  SaveFileName:= ChangeFileExt(GetField(fieldFilePath),'.nfo');
  if SaveFileName = '.nfo' then
    XBOX_Movies_Path:='';
    if XBOX_Movies_Path='' then XBOX_Movies_Path:='D:\Movie\';
    i := 0;
    Ask('Set Pathname to save your files if no FilePath-Field exists', XBOX_Movies_Path);
    while i = 0 do
      if not DirectoryExists(XBOX_Movies_Path) then
         Ask('Set Pathname to save your files if no FilePath-Field exists. Path must already exist!!', XBOX_Movies_Path);
        i := 1;
  if SaveFileName='' then EXIT;
  if Pos('.nfo', SaveFileName)+Pos('.NFO', SaveFileName)=0 then SaveFileName:=SaveFileName+'.nfo';
  sl.Append('<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>');
  sl.Append('<movie>');
  MovieNumber:=GetField(fieldNumber);
  sx:='';
  //Movie info ordered as it appears on XBMC screen.
  //The fields we don't have in AMC are commented-out. Leave blank or put other fields there.
  if GetField(fieldTranslatedTitle) <> '' then
    sx:=sx+'    <title>'           + GetField(fieldTranslatedTitle) + '</title>'+#13#10
    sx:=sx+'    <title>'           + GetField(fieldOriginalTitle) + '</title>'+#13#10 ;
  sx:=sx+'    <director>'        + GetField(fieldDirector)        + '</director>'+#13#10;
//sx:=sx+'    <credits>'         + GetField(fieldRating)               + '</credits>'+#13#10;
  sx:=sx+'    <genre>'           + GetField(fieldCategory)        + '</genre>'+#13#10;
  sx:=sx+'    <year>'            + GetField(fieldYear)            + '</year>'+#13#10;
//sx:=sx+'    <tagline>'         + GetField(field )               + '</tagline>'+#13#10;
//sx:=sx+'    <outline>'         + GetField(field )               + '</outline>'+#13#10;
  sx:=sx+'    <rating>'          + GetField(fieldRating)          + '</rating>'+#13#10;
//sx:=sx+'    <votes>'           + GetField(field )               + '</votes>'+#13#10;
  sx:=sx+'    <runtime>'         + GetField(fieldLength)+' min'   + '</runtime>'+#13#10;
//sx:=sx+'    <mpaa>'            + GetField(field )               + '</mpaa>'+#13#10;
  sx:=sx+'    <plot>'            + GetField(fieldDescription)     + '</plot>'+#13#10;
//Original Title, not visible though:
  sx:=sx+'    <originaltitle>'   + GetField(fieldOriginalTitle)   + '</originaltitle>'+#13#10;
//Additional xml fields that can be left blank or assigned to whatever:
//sx:=sx+'    <top250>'          + GetField(field )               + '</top250>'+#13#10;
//sx:=sx+'    <season>'          + GetField(field )               + '</season>'+#13#10;
//sx:=sx+'    <episode>'         + GetField(field )               + '</episode>'+#13#10;
//sx:=sx+'    <thumb>'           + GetField(field )               + '</thumb>'+#13#10; // http://127.0.0.1/dummy.jpg
//sx:=sx+'    <watched>'         + GetField(field )               + '</watched>'+#13#10;
//sx:=sx+'    <searchstring>'    + GetField(field )               + '</searchstring>'+#13#10;
//sx:=sx+'    <file>'            + GetField(field )               + '</file>'+#13#10;
//sx:=sx+'    <path>'            + GetField(field )               + '</path>'+#13#10; // seems not needed
//sx:=sx+'    <premiered>'       + GetField(field )               + '</premiered>'+#13#10;
//sx:=sx+'    <status>'          + GetField(field )               + '</status>'+#13#10;
//sx:=sx+'    <code>'            + GetField(field )               + '</code>'+#13#10;
//sx:=sx+'    <aired>'           + GetField(field )               + '</aired>'+#13#10;
  sx:=sx+'  </movie>';
  sl.Append(UTF8Encode(sx));
  //save sl.savefilename
    i:= 0;
    SaveFilename := GetField(fieldOriginalTitle);
    while i=0 do
      if Pos('<', SaveFileName) + Pos('>', SaveFileName)+ Pos(':', SaveFileName)+
           Pos('"', SaveFileName) + Pos('/', SaveFileName)+ Pos('\', SaveFileName)+
           Pos('|', SaveFileName) + Pos('?', SaveFileName)+ Pos('*', SaveFileName) >0 then
           Ask('Origintal title contains  < > : " / \ | ? *  ) , if other illegal characters.'+#13#10 +
                ' are used then files wil not be created ' + #13#10 + ' Please Correct filename!!', SaveFileName)
          i:=1;
  SaveFileName := XBOX_Movies_Path + SaveFileName + '.nfo';
  SFilename := ChangeFileExt(SaveFileName,'-poster' + PictureExt);
  sl.SaveToFile(SaveFileName);
  sl.Free;
  ExportPicture(SFileName);
[/code]
tiagoaquino
Nice...
Post by tiagoaquino »
I found it really interesting and I'm trying to improve it.. But I ended up facing some difficulties, I hope this community is able to help.
In ANT, we can add multiple actors (or genres) by adding a comma (,) between them. In Kodi we must add them individually in their on tags. As I'm familiar with programming, I believe there is a way to read the field and keep adding tags until no comma is found, excluding spaces around them (a "for loop" "while", don't know).
Can someone help with that?
It should not be very difficult indeed, if you add a "uses StringUtils1;" at the top (after the "program" line) you can use a function "TextBefore" that can be useful for that.
e.g.: (there is probably cleaner way to do that, it is just quickly written code)
  Actors, s: String;
Actors := GetField(fieldActors);
while Actors <> '' do
  if Pos(',' Actors) = 0 then
    s := Actors;
    Actors := '';
    s := TextBefore(Actors, ',', '');
    Actors := RemainingText;
    here you have an actor name in the variable "s", that you can use to generate a new actor tag
tiagoaquino
antp wrote:It should not be very difficult indeed, if you add a "uses StringUtils1;" at the top (after the "program" line) you can use a function "TextBefore" that can be useful for that.
  Actors, s: String;
    s := Actors;
    Actors := '';
We're almost there.. I've made some minor changes on your code due to compilation warnings. I ended up with this (also change variable names to use them more than once):
TxtAux := GetField(fieldActors);
while TxtAux <> '' do
  if Pos(',',TxtAux) = 0 then
    sAux := TxtAux;
    TxtAux := '';
    sAux := TextBefore(TxtAux, ',', '');
    TxtAux := RemainingText;
  sx:=sx+'    <actor>'+#13#10'        <name>'     + sAux          + '</name>'+#13#10'    </actors>'+#13#10;
Right now, the script is running, generating this output:
    <actor>
        <name>Darryl Alan Reed</name>
    </actors>
    <actor>
        <name> Valente Rodriguez</name>
    </actors>
    <actor>
        <name> Yvette Nicole Brown</name>
    </actors>
    <actor>
        <name> Nicole Vicius</name>
    </actors>
As you can see, we're almost there. There is a blank space before the actor name. And depending on some case, there might be a space at the end. So.. is there a way to remove leading and trailing spaces?
tiagoaquino
tiagoaquino wrote:is there a way to remove leading and trailing spaces?
fulltrim(sAux) does it! Done!
tiagoaquino
Ok.. now how it came out:
Director, Country, Genre and Actors may be multiple values. There's also some Custom Fields on this script for SortTitle and Set tags (more info in Kodi documentation: http://kodi.wiki/view/NFO_files/Movies), if you don't use it, you leave it commented
Authors=Harald
Site=
Language=EN
Version=1.0
Requires=3.5.0
GetInfo=0
RequiresMovies=1
[Parameters]
program AMCtoSimpleKodiXMLExport; uses StringUtils1;
  TxtAux: string;
  sAux: string;
  sx: string;
  sl: TStringList;
  i:integer;
    i := 0;
    while i = 0 do
        i := 1;
  sx:='';
TxtAux := GetField(fieldDirector);
    sAux := TxtAux;
    TxtAux := '';
  sx:=sx+'    <director>'        + fulltrim(sAux)        + '</director>'+#13#10;
//sx:=sx+'    <credits>'         + GetField(field )               + '</credits>'+#13#10;
TxtAux := GetField(fieldCategory);
    sAux := TxtAux;
    TxtAux := '';
  sx:=sx+'    <genre>'           + fulltrim(sAux)        + '</genre>'+#13#10;
  sx:=sx+'    <runtime>'         + GetField(fieldLength)          + '</runtime>'+#13#10;
  sx:=sx+'    <id>'              + GetField(fieldMedia)           + '</id>'+#13#10;
    sAux := TxtAux;
    TxtAux := '';
  sx:=sx+'    <actor>'+#13#10'        <name>'     + fulltrim(sAux)          + '</name>'+#13#10'    </actor>'+#13#10;
TxtAux := GetField(fieldCountry);
    sAux := TxtAux;
    TxtAux := '';
  sx:=sx+'    <country>'         + fulltrim(sAux)         + '</country>'+#13#10;
//  if GetCustomField('SortTitle') <> '' then
//  sx:=sx+'    <sorttitle>'       + GetCustomField('SortTitle')    + '</sorttitle>'+#13#10;
//  if GetCustomField('Set') <> '' then
//  sx:=sx+'    <set>'             + GetCustomField('Set')    + '</set>'+#13#10;
  sx:=sx+'  </movie>';
    i:= 0;
    while i=0 do
          i:=1;
  sl.Free;
Madstorm
Re: Script for export to Kodi ( 15.x tested)
Post by Madstorm »
Hello,
I use Antmovie since > 10 years, great no doubt.
I've switched on XBMC - Kodi since 5, and export antmovie catalog to .nfo then import with local info in Kodi.
Works great...
BUT...one feature is not correctly handled in the .nfo file...the god dam <role> tag...
The reason is : In Kodi, if i want to get all movies available in my library with a particular actor, it doesn't work...and it is frustrating !!!
Example of what i need ! (the ActorsToXml function which is available in scripts section doesn't do the job !!!)
Actors field in antmovie :
Oskar Werner (Guy Montag), Julie Christie (Linda/Clarisse), Cyril Cusack (le capitaine), Anton Diffring (Fabian), Jeremy Spenser (l'homme avec les pommes), Bee Duffell (la dame aux livres), Michael Balfour (Machiavelli), Anna Palk (Jackie), Alex Scott (Book Person: 'The Life of Henry Brulard'), Ann Bell (Doris), Arthur Cox (Male Nurse), Frank Cox (Book Person: 'Prejudice').
I need something like that in the .nfo export with actor, name + role :
<actor>
<name>Oskar Werner</name>
<role>Guy Montag</role>
</actor>
in 2008, this guy seems to have post the solution
https://forum.kodi.tv/showthread.php?tid=31511&page=2
not active anymore...
Is there somebody with the solution ?
Thank you very much
Rgs
M
