Overview Column not shown
Calade
Post by Calade »
Hi all,
I use Windows 7.
When I want see the new names generated BEFORE really rename the files, the "overview" colum is at the extreme right of the screen and I can't move it to the left, it seems blocked.
Am I wrong or is it a bug ?
Thanks for your replies.
The "preview" column?
It can be freely moved; I just tested with version 2.12 on Windows 8.1, that should still work fine on Windows 7 as far as I know... (I suppose you have the version 2.12).
When you try to move it, small arrows should appear where it will be moved.
If it does not work you may try editing directly the renamer.xml config file and change the values in FilesListColumns (change Position values)
Calade
Post by Calade »
Thanks for your reply.
I have version 2.12 on Win 7
I know that I ought being able to resize columns with the mouse (lik in windows explorer), but in that case, it didn't work.
I have tried by modifying the renamer.xml files (they are 2 in fact), but none were running.
I must uninstall ant renamer (reboot my PC but that is Windows :mad: )
and reinstall.
Now it seems right.
Thanks again.
