Hi, first of all I´d like to say sorry for my terrible english.
Right now I´m not using your fantastic program for my TV series because I have a problem: How can I create subcategories? I mean, imagine I´d like to create a TV categorie, inside this one there should be "The Simpsons" (for example) and inside that, each episode...
I know that I can create TV Serie-The Simpsons Category, but i don´t like this way because I want tree structure.
That´s all, thanks a lot.
PD.- Ant movie catalog is a really good program, but I think it´d reach an amazing level if it had some new features:
Subcatecories.
More than a picture per movie.
Full customizable look, with skins or something like that.
.ogm compatibility.
Thanks again.
How to store TV Series
For the moment the only way to get a tree structure is to use the "group by" feature (Tools menu)
In the future versions I'll maybe add a more advanced tree system where you can make "collection items" etc.
In the next version I plan to add multiple images, and OGM support should be added also in one of the next versions.
For the skinning, I'll never add it. If you want a different look, change the look of your system, e.g. with XP themes
The toolbar skinning is there because the toolbar system that I use allows it, but I would not have added it if it was not included by default
