Question about Windows 10 Drag&Drop
SMoriarty
Post by SMoriarty »
Hello.
I am using Ant Renamer 2.12 on Windows 10. The renaming functions work well and have been very useful.
When I try to drag&drop files onto the desktop shortcut, or to use "sendto" to send a list of selected files to Renamer, the files are not "transferred".
I am unable to drop either files or folder into an open instance of Renamer. I try to copy them to the Files window, and the windows cursor changes to indicate that the transfer will happen, but no files are transferred.
Should I expect those operations to work, or is it the case that only folders work and that Renamer doesn't expect to have files or folders "dropped onto" it while it is running?
Hello,
Indeed, the drag & drop does not seem to work on my Windows 10 either (not my main computer, hence why I hadn't yet notice it).
Strange that you are the first to report the problem.
I wonder what cause that, I'll try to investigate.
