Bing Picture Search
Tadeu64
Bing Picture Search
Post by Tadeu64 »
I did the Google Script some years ago, but it is not working anymore, since Google has now all strings encrypted. So, I tried to move to Bing, and at least it works.
But I need some help to improve the script because I was trying to:
- Show a thumbnail instead of a title (actualy, the title is the URL, but it does not help me to choose the right image)
- Show messages each time I find one image, but not asking for "OK" as the ShowMessage does.
Any ideas?
Authors=Tadeu Cunha
Title=Bing Picture Import
Description=Get picture from bing.com images
Site=http://www.bing.com
Language=EN
Version=1.00 - 01.06.2013
Requires=3.5.0
Comments=See code comments. Thanks to the authors of IMDB.ifs and IAFD.ifs
License=GPL
RequiresMovies=1
AutoSelect=0|1|0=Always show movie selection dialog|1=Auto-select movie if there is only one
GetOnlyFirstPicture=0|1|0=Show available pictures|1=Get Only the first picture found
IncludeTheWordCover=1|1|0=Normal search|1=Include COVER as text string
[Parameters]
program BingPics;
// no mail; comments only in web
  StringUtils1;
  BaseURL  = 'http://www.bing.com/images/search?q=';
  MaxItems = 50;
function RemoveBrackets(wholetext: string) : string;
  str1: String;
  str1 := Trim(TextBefore(wholetext, '[', ''));
  if str1 <> '' then
    if Pos(']', RemainingText) > 0 then
      wholetext := str1+' '+Trim(TextAfter(RemainingText, ']'));  // + end of text or ''
  result := Trim(wholetext);
function RemovePar(wholetext: string) : string;
  str1: String;
  str1 := Trim(TextBefore(wholetext, '(', ''));
  if str1 <> '' then
    if Pos(')', RemainingText) > 0 then
      wholetext := str1+' '+Trim(TextAfter(RemainingText, ')'));  // + end of text or ''
  ImgCnt: Integer;
  PageText,strRef,strImg,strTest: string;
  // Read the whole page
  PageText := GetPage(Address);
  // Looks for the first images
  ImgCnt:= MaxItems;
  PickTreeTitle(MovieName);
  while ImgCnt > 0 do
    // Looks for all tags href
    strTest := TextBetween(PageText,'<a href','</a>');
    if (strTest = '') then
      break;
    PageText := RemainingText;
    // Check if there is a class with the url inside this href
    if pos('class="thumb"', strTest) > 0 then
      // Get the img reference
      strImg := TextBetween(strTest,'="','" class="thumb"');
      if (GetOption('GetOnlyFirstPicture') = 1) then
        // That's it, we have the picture!
        GetPicture (strImg);
      // Add this option to the tree
      // ShowMessage(strImg);
      PickTreeAdd(strImg, strImg);
      ImgCnt := ImgCnt - 1;
  if (ImgCnt = MaxItems) then
    ShowError('Error: Images not found! Probably something changed at Bing :(');
    // User choose the image, get it!
    if PickTreeExec(strImg) then
  //SetField(fieldChecked, '');
  if MovieName = '' then MovieName := GetField(fieldTranslatedTitle);
  if (GetOption('AutoSelect') = 0) or (MovieName = '') then
   if Input('Bing Picture Search', 'Input title:', MovieName) = False then exit;
  MovieName := RemovePar(RemoveBrackets(MovieName));
  if(GetOption('IncludeTheWordCover') = 1) then
    MovieName := 'COVER ' + MovieName;
  AnalyzePage(BaseURL + UrlEncode(MovieName));
Re: Bing Picture Search
Tadeu64 wrote:But I need some help to improve the script because I was trying to:
Any ideas?
Wonderful script! :grinking:
I don't know if it is possible to show a picture in a picklist but I think it would be useful (in selection) to show description and image dimensions (parameters t1 and t2 in bing's search page source code) instead of image's http link.
What do you think? ;)
