AMC Online?
AMC Online?
Is it possible to upload AMC to a server, manage it online, and create a website supported on AMC?
JOSE
AMC online
My idea is to upload the database that I am building with AMC to a website.
My question is if it is possible, for instance, exporting to MySLQ.
3xodus alias Procat
- Contact:
THIS would the best idea to give third choice about storing data. I have my own mysql database driven web site where i have list of my movies. It would be perfect if Movie Catalog could work with MySQL directly instead of going through export and import. Sometimes you notice a small misprint or mistake and you have to go Movie Catalog, edit, then export and import.antp wrote:I do not understand what you mean exactly... you mean put the data online but still allow to access to it with AMC ?
It may be an idea for a future version... the easiest solution would be a MySQL database (or any other database) but most of the servers do not accept connections from foreign hosts.
I found the other way around. I need to save my catalog in XML format and then just parse it using PHP. But i don't like it
Sure. Whatever you wantantp wrote:Does it allow external connections ?SiburNY wrote:I have my own mysql database driven web site
I use EMS MySQL Manager. This program connects directly to MySQL server without any problem. When you create a user, it lets you specify what ip address he can connect from. It could be just localhost, or a range of ip's, or just "%" - any ip
I was thinking that it was on a usual public server, which usually do not allow external connections
I'll probably try to make something for MySQL, but I will probably do it through PHP scripts so it will allow to use it also for hosts that protect their SQL server (here the scripts will be hosted on the web server so they can access to the SQL database, and they can be called from outsite).
