I have created a crude script to pull down * ratings from a website into a custom field in my catalog.
It works, but I don't really want to hammer the site with queries. Since the script points to a static address/webpage, I have saved the the single page of HTML code to my HDD.
How can I refernence that instead? Changing the "GetPage" value as below returns a 404 not found error.
page := GetPage('file:///D:/amctest/3.5%20star.htm');
page := GetPage('D:\amctest\3.5 star.htm');
Is there another function I need to use in order to query local hosted files / plain text?
Thanks!
How to reference HTML page cached on local HDD within script
daws0n
daws0n
s := GetField(fieldOriginalTitle);
value := textbetween(page, '<h1 id="search-results">', '<hr class="no-css" />');
value := FullTrim(value);
i := Pos(s, value);
if i > 1 then
setCustomField('JBStarRating', '3.5');
end.It's not 100% accurate, but does not an OK job.
daws0n
To read/write text files you could use something like that:
(using a classic path like 'c:\folder\file')
function LoadFromFile(FileName: string): string;
Page.LoadFromFile(FileName);
Result := Page.Text;
procedure SaveToFile(Text: string; FileName: string);
Page.Text := Text;
Page.SaveToFile(FileName);
