IMDB ACTORS
spiderbat
IMDB ACTORS
Post by spiderbat »
Bonjour le script IMDB ACTOR ne fonctionne plus...voila ce qui s'affiche quand je télécharge "page error at 1777 - titre du film".. quelqu'un aurais une solution..merci
spiderbat
Post by spiderbat »
autant pour moi,le script a re fonctionné ce matin tout seul :/ :/ ...allez comprendre.
ayushchandra
Post by ayushchandra »
I am also dealing with this "Actors" problem. Can anyone knows how to fix it?
J
Post by J »
be patient pls.
will try to check it at weekend.
spiderbat
Post by spiderbat »
OK thank you ;)
J
Post by J »
hm, just tested with a couple of movies and it still works perfectly for me.
Can you tell me at which point the error appears?
Which script options do you have set?
btw. pls. write in english, my french level is at zero ;)
spiderbat
Post by spiderbat »
hello, the script works again I Started On program and everything works ...sorry for my english no perfect :/
J
Post by J »
alright then, perhaps it was just a temporary server side problem/change of something.
Don't worry about your english, it's much better than my french ;)
enjoy
J.
