Problem with printing, cutting off left side of page
rcav8or
Post by rcav8or »
Hi, I am using the 3 column print template. On 2 different printers, it cuts off half the title column, on the left side. I did use the designer, and just have 2 columns, and it still cuts off half the title, like the whole page is shifted to the left 3 or 4 inches. Couldn't find any solutions in a search. I don't think it's a printer issue, because I used two different printers.
Thanks!
rcav8or
It can be an issue occurring on 2 printers :D
You may try to increase the margins, as many printers don't like when text is too close to the borders.
Or print to a virtual PDF printer (e.g. CutePDF or PDFCreator) and then print the result PDF.
