[REL][EN] DVD Empire updated script
deadeye
Post by deadeye »
Updated to deal with site changes.
Authors=dmitry501,Pavel Uher,Chetan Rao,Deadeye
Title=DVDEmpire.com
Description=Import script for DVD Empire
Site=http://www.dvdempire.com
Language=EN
Version=2.2.3
Requires=4.1.0
Comments=
RequiresMovies=1
MediaType=2|0|0=All Products|1=DVD|2=Blu-ray
PictureType=1|0|0=Large Picture|1=Small Picture
ClearCheckMark=1|0|0=No|1=Yes
[Parameters]
program DVDEmpire;
  StringUtils1;
  LF = #13#10;
  MediaType: string;
  UpdateFile: TStringList;
// ********** Get multiple values from a string **********
// ********** Returns string with comma or linefeed between each item **********
function GetMultiValues(Line : String; StartTag : String; EndTag : String; UseCommaDelimiter : Boolean): String;
    Value     : String;
    Delimiter : String;
  Result := '';
  if (UseCommaDelimiter) then
    Delimiter := ', '
    Delimiter := LF;
  while(true) do
    Value := TextBetween(Line, StartTag, EndTag);
    if Value = '' then
      break
      HTMLDecode(Value);
      HTMLRemoveTags(Value);
      if Pos(Value, Result) = 0 then     // if not a duplicate
        if (Length(Result) > 0) then
          Result := Result + Delimiter;
        Result := Result + Value;
      Line := RemainingText;
// ********** Gets the specific movie info **********
procedure GetMovieInfo(Address: String);
var PageText, Value, TempValue : String;
    hours, mins : Integer;
  PageText := GetPage(Address);
  // URL
  // Picture
  Value := TextBetween(PageText, '<div id="Boxcover"><a href="', '" class="fancy"');
  if GetOption('PictureType') = 1 then
    Value := StringReplace(Value, 'h.jpg', 'm.jpg');
  GetPicture(Value);
  // Original Title
  Value := TextBetween(PageText, '<meta itemprop="name" content="', '"');
  HTMLDecode(Value);
  // Media Type
  Value := TextBetween(PageText, 'class="active">', '</a>');
  // Description
  Value := TextBetween(PageText, '<p class="Tagline">', '</div>');
  Value := StringReplace(Value, '</p><p>', LF);
  Value := StringReplace(Value, '®', '®');
  HTMLDecode(Value);
  Value := FullTrim(Value);
  // Length
  Value := Trim(TextBetween(PageText, '<strong>Length</strong>', '<br/>'));
  if Value <> '' then
    hours := StrToInt(Trim(TextBefore(Value, ' hrs', '')),1);
    mins := StrToInt(Trim(TextBetween(Value, 'hrs. ', ' mins')),1);
    Value := IntToStr(hours*60+mins);
    SetField(fieldLength, Value);
  // Rating
  Value := 'Rating: ' + Trim(TextBetween(PageText, '<span itemprop="contentRating"> ', '</span>'));
  // Year
  Value := Trim(TextBetween(PageText, '<strong>Production Year</strong>', '<br/>'));
  SetField(fieldYear, Value);
  // Number of Discs
  Value := Trim(TextBetween(PageText, '<strong>Number of Discs</strong>', '<br/>'));
  SetField(fieldDisks, Value);
  // Subtitles
  Value := Trim(TextBetween(PageText, '<strong>Subtitles</strong>', '<br/>'));
  SetField(fieldSubtitles, Value);
  // Video format
  Value := Trim(TextBetween(PageText, '<strong>Video</strong>', '<strong>'));
  SetField(fieldVideoFormat, Value);
  // Audio
  TempValue := FullTrim(TextBetween(PageText, '<strong>Audio</strong><br />', '</div>'));
  if TempValue <> '' then
    TempValue := RemoveSpaces(TempValue, true);
    Value := TextBetween(TempValue, ' ', '<br />');
    SetField(fieldAudioFormat, Value);
    // Languages
    Value := '<br />' + TempValue;
    Value := GetMultiValues(Value, '<br />', ' ', true);
  // Actors
  Value := FullTrim(TextBetween(PageText, '<h3>Cast</h3>', '</div>'));
  Value := GetMultiValues(Value, '">', '</a>', false);
  SetField(fieldActors, Value);
  // Producer(s)
  Value := FullTrim(TextBetween(PageText, '<h3>Production</h3>', '</div>'));
  Value := GetMultiValues(Value, '<span itemprop="name">', '</span>', true);
  // Director(s)
  Value := FullTrim(TextBetween(PageText, '<h3>Director</h3>', '</div>'));
  Value := GetMultiValues(Value, '">', '</a>', true);
  // Clear Check Mark
  if GetOption('ClearCheckMark') = 1 then
    SetField(fieldChecked, 'false');
// ********** Gets the movie titles/addresses from the search results page **********
  LineNr, L: Integer;
  PageText, MovieText: string;
  MovieAddress, MovieTitle, MovieYear: string;
  L := StrToInt(TextBetween(PageText, '<span class="matches-found"><strong>', '</strong> Matches Found'),1);
  PageText := RemainingText;
  if L > 0 then
    if L > 50 then
      PickTreeAdd('First 50 results of ' + IntToStr(L), '');
      L := 50;
      PickTreeAdd(IntToStr(L)+' Matches found', '');
      // Get the info of one result
      MovieText := TextBetween(PageText, '<h3><small>', '<ul class="item-details spacing-bottom-alt">');
      // find the link
      MovieAddress := 'http://www.dvdempire.com' + TextBetween(MovieText, '<a href="', '"');
      MovieText := RemainingText;
      // find the movie name
      MovieTitle := TextBetween(MovieText, 'title="', '"');
      // find the year
      MovieYear := FullTrim(TextBetween(MovieText, ' <small>(', ')</small>'));    // movie release year
      if MovieYear <> '' then
        MovieTitle := MovieTitle + ' [' + MovieYear + ']';
      // add it to the tree
      HTMLDecode(MovieTitle);
      HTMLRemoveTags(MovieTitle);
      // decrement counter
      L := L - 1;
    until L = 0;
    GetMovieInfo(Address);
// ********** Begin program **********
    if ShowWarning('Old version of file "Stringutils1.pas" detected: v' + IntToStr(StringUtils1_Version) + LF + 'The script requires at least version 7.' + LF + 'Download and install latest version now ?') = True then
      UpdateFile.Text := GetPage('http://update.antp.be/amc/scripts/StringUtils1.pas');
      UpdateFile.Free;
      ShowInformation('StringUtils1 has been updated. Please restart the DVD Empire script now. Thank you.');
      Exit;
      ShowInformation('You can download latest version of "StringUtils1.pas" using script "update scripts" or via http://update.antp.be/amc/scripts');
      Exit;
  // Check for current AMC version
  if CheckVersion(4,1,0) then
    PickListClear;
    if not Input('Import from DVD Empire', 'Enter the title or the URL of the movie:', MovieName) then
      Exit;
    if Pos('dvdempire.com', MovieName) > 0 then
      AnalyzePage(MovieName)
      MovieName := AnsiLowerCase(MovieName);
      MovieName := StringReplace(MovieName, '’', '');
      MovieName := StringReplace(MovieName, Chr(39), '');
      MovieName := StringReplace(MovieName, ' ', '+');
      MovieName := StringReplace(MovieName, '&', '%26');
      MovieName := StringReplace(MovieName, ':', '%3A');
      MediaType := 'allsearch';
      // DVD
      if GetOption('MediaType')=1 then MediaType := 'dvd';
      // Blu-ray
      if GetOption('MediaType')=2 then MediaType := 'blu-ray';
      AnalyzePage('http://www.dvdempire.com/' + MediaType + '/search?exactMatch=' + MovieName + '&q=' + MovieName + '&sort=score&pageSize=50');
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least version 4.1.0)');
Thanks.
I notice that in your version the "YearOption" option is gone, did you remove it because it was not available anymore on the site? Or did you start from a different version of the script than the one I had?
deadeye
Post by deadeye »
I was using it on the search results page, but now they only show the release date there.
However, on the movie info page, they show both production date and release date. I'll look to add this to the script soon.
