(Bug) mouse scrolling & 2 windows/fields
xenesys
Post by xenesys »
Hi
I meet a little bug : a mouse + scrolling = 2 windows in AMC are scrolling together.... I close and re-open = the problem disappeared and reappeared.
https://www.dropbox.com/s/wk9gk3sj29h9h ... 8.png?dl=0
Edit : I found a thing :
1 - I'm in the main window (N° et titles) = scrolling alone
2 - I'm going to the "comments" field = scrolling with the main window
3 - I'm going back to the main window = scrolling it alone again.
Version AMC : 4.2.1
Windows 10 pro 64bits
Thanks for your help. ;)
Post by soulsnake »
I already see this bug on some laptops with special scrolling options for the touchpad : "Scroll item under pointer" instead of "Scroll selected item" by default.
The movie list seems to handle the scroll event every time it has the focus, even if another item handle it before.
Is it the case for you ?
When you go to the "comments" field, do you click on the field or not to give it focus ?
xenesys
Post by xenesys »
I'm not on a laptop. It's a classic PC with a mouse and keyboard.
No I don't click in the "comments" field before scrolling.
I don't change anything beetween AMC 4.2.0 & 4.2.1 and win 7 & 10 (mouse option or anything else).
Can I try a thing to correct it or is it AMC ?
soulsnake wrote: I already see this bug on some laptops with special scrolling options for the touchpad : "Scroll item under pointer" instead of "Scroll selected item" by default.
Some mouse drivers had such features too, some time ago (a lot of years :D) Logitech drivers did that if I remember well
xenesys
Post by xenesys »
I have a logitech mouse M500 but I don't see an option in the setpoint software.
Post by soulsnake »
So it is strange if you have not changed hardware.
Maybe drivers have changed with Windows 10 ?
Can you try with another mouse ?
Anyway, I will see to fix this bug when I will have a little time.
xenesys wrote:I have a logitech mouse M500 but I don't see an option in the setpoint software.
Back when I noticed that, this behaviour occurred just by default with these drivers, compared to Windows' standard driver behaviour.
xenesys
Post by xenesys »
Setpoint updated but problem is still there.
My other mouse is also a logitech so.... ^^'''
I will try to uninstall setpoint and report the result.
Post by soulsnake »
I think I found the problem.
It will be fixed for the next release ;).
xenesys
Post by xenesys »
hoho thanks! great job. ^^
I had sometime very freaky bugs in scripts but in the software it's the first time.
