Move string
JUANFERNANDEZ
Move string
Post by JUANFERNANDEZ »
I need to move a string in a file as example:
nombre1-nombre2.txt --> nombre2-nombre1.txt
How move a string from a character to a position?
It depends what exactly needs to be done.
If you need to swap what is on both sides of a "-" the easiest way to achieve that is to use Regular Expressions.
Expression = (.+)-(.+)\.([^\.]+)
Mask = $2-$1.$3
