[UPD] discogs.com script - version 1.4.1
Authors=Fulvio53s03
Title=Discogs
Description=import album
Site=http://www.discogs.com
Language=IT, EN
Version=1.4.1
Requires=4.2.0
Comments=It can be used to search informations (mode=0) and to extract them to your AMC d.b. or to extract directly informations (mode=1), if you already know your album address' page in discogs. For a better selecting informations, you can also supply Artist's name in Original Title field and the information: CD, Album, LP ecc. in Media Type field.
License=*  The source code of the script can be used in   |*  another program only if full credits to Fulvio53s03  |*  script
RequiresMovies=1
Mode=1|0|0=normal mode|1=batch mode (url)
[Parameters]
// TypeSearch=1|1|1=search for exact expression|2=search for any word
// TypeOrder=3|3|1=order by Artist|2=order by Album Title|3=order by relevance
// needs the following units
// StringUtils7552.pas
program discogs;
   StringUtils7552;
   discogsUrl = 'http://www.discogs.com';                // base url
//<div class="pagination_controls ">                              inizio links
//<div class="pagination bottom">                                 fine links
//<div class="cards cards_layout_large" id="search_results">      inizio struttura interna link
   AllAlbumUrl = 'http://www.discogs.com';                // base url
   batchlogfic = 'c:\discogs_batch.txt';                  // log for batch mode
   debug_search = false;                               	 // debug mode on/off su ricerca dischi
   debug_album = false;                                   // debug mode on/off su estrazione dati album
   folder = 'c:\';                                       // directory where to save files
   inizio_e_fine_traccia = '<td class="tracklist_track_pos">';
   inizio_credits = '<li>';
   fine_credits = '</li>';
   CRLFspace = CRLF + ' ';
   nuovo_anno, mese_anno, solo_anno, data_rilascio, label: String;
   Credit_address, Readdress, Page: String;
   AlbumName, ArtistName, firstcall, abort, name, Dati_traccia, autori: String;
   Formato, Releases, artista: String;
   pag_ricerca, Commento, save_value, ordine_lista, Salva_autore: String;
   value: string;
   Album_ok: boolean;
   BatchMode, index, lungo: Integer;
   brani, Track, newtrack, old_track, datitrack: String;
   titolo_e_autore, titolo, autore: String;
   batchlog, confbatch: TstringList;
   save_pag, artist, initchar, endchar: string;
   albumok: boolean;
// list of albums
procedure GetList;
   Address, urlmusic, album, albumtest, label, genre: String;
   Save_address, Title_album, indir_album, indir_title_album: String;
   Relevance, info_disco, artist_album, tipo_release, altri_dati: String;
   dati_album, init_control, end_control: String;
   Desc_ricerca: String;
   ctr_loop: integer;
   found: boolean;
   i, lgth_dati_album, lgth_pag_ricerca: integer;
   //  http://www.discogs.com/search/?q=bitches+brew
   PickTreeClear;                                                    // clear list
//   http://www.discogs.com/search/?q=Symphony+X&type=all
//fs20150727   Address :=  discogsUrl + '/search/?q=' + UrlEncode(AlbumName) + '&layout=sm';       //fs
   Address :=  discogsUrl + '/search/?q=' + AlbumName + '&layout=sm';           //fs20150727
//fs2015.06.10   Address :=  discogsUrl + '/search/?q=' + AlbumName + ' ';
//fs2015.06.10   Address := Address + ArtistName + '&format_exact=' + formato + '&layout=sm';       //fs
//   Address :=  discogsUrl + '/search/?q=' + AlbumName + '&type=all';  //fs2015.06.10
   Address := UrlEncode(Address);
   Desc_ricerca := '"' + AlbumName + '"';
   if length(ArtistName) > 0  then
      Desc_ricerca := Desc_ricerca + ', ' + ArtistName;
   if length(formato) > 0 then
      Desc_ricerca := Desc_ricerca + ', ' + formato;
   Page := GetPage(Address);
   Save_address := Address;
   HTMLdecode(Page);
   found := False;
//   PickTreeAdd('List of albums found for' + '"' + AlbumName + '"', '');
   PickTreeAdd('List of albums found for ' + Desc_ricerca, '');
   if debug_search then
      DumpPage(folder+'discogsList.txt', Page);                // debug
   if Pos('find anything', Page) <> 0 then
      LogMessage('Error while reading selection page - no results found for ' + Desc_ricerca);
   init_control := '<div class="pagination_controls ">';
   end_control  := '<div class="pagination bottom ">';
   info_disco := '<div class="card_body">';
   pag_ricerca := init_control + TextBetween(Page, init_control, end_control) + end_control;      //elenco titoli richiesti
   lgth_pag_ricerca := length(pag_ricerca);
   Normalizza_Page(pag_ricerca);
   save_pag := pag_ricerca;
      DumpPage(folder+'discogs_pag_ricerca.txt', pag_ricerca);                // debug
   dati_album := info_disco + TextBetween (pag_ricerca, info_disco, info_disco) + info_disco;
   //dati_album contiene recursivamente i dati degli album
   lgth_dati_album := length(dati_album);
      DumpPage(folder+'discogs_dati_album.txt', dati_album);                // debug
   delete(Pag_ricerca, 1, length(dati_album) - length(endchar));
   ctr_loop := 0;
   lungo := (Length(info_disco) + length(info_disco));
   while (lgth_dati_album > Lungo) and (ctr_loop < 50) do                 //estraggo al massimo 50 titoli
      ctr_loop := ctr_loop + 1;
      initchar := '<a class="search_result_title';
      endchar  := '</a>';
      indir_title_album := textBetween(dati_album, initchar, endchar) + endchar;
      initchar := 'href="';
      endchar  := '"';
      Address  := discogsUrl + textBetween(indir_title_album,initchar, endchar);
      initchar := '<a href="/artist';
      endchar  := '</span>';
      artist_album  := textBetween(dati_album,initchar, endchar);              //Artista
      initchar := '>';
      endchar  := '<';
      artist_album  := textBetween(artist_album,initchar, endchar);             //Artista
      initchar := '>';
      endchar  := '</a>';
      Title_album  := textBetween(indir_title_album,initchar, endchar);            //titolo dell'album
      initchar := '<p class="card_status">';
      endchar  := '</p>';
      tipo_release := textbetween(dati_album, initchar, endchar);
      tipo_release := formatText(tipo_release);                                    //tipo release
      initchar := '<p class="card_info">';
      endchar  := '</p>';
      altri_dati := textbetween(Dati_album, initchar, endchar);
      altri_dati := formatText(altri_dati);
      Title_Album := artist_album + ' - ' + Title_Album + ' (' + tipo_release + ', ' + altri_dati + ')';
      Title_Album := stringreplace(Title_Album, CRLF, '');
      Title_Album := stringreplace(Title_Album, ' Needs Vote,', '');
      PickTreeAdd(Title_Album, Address);
      found := True;
      delete(Pag_ricerca, 1, lgth_dati_album);
      Pag_ricerca := Pag_ricerca + info_disco;                         //fs 2015_01_12
      lgth_pag_ricerca := length(Pag_ricerca);
      dati_album := info_disco + TextBetween (pag_ricerca, info_disco, info_disco);     //recursivamente i dati degli album
      lgth_dati_album := length(Dati_album);
   if not found then
      LogMessage('No album found for '+AlbumName);
      AnalyzeMusicPage(Address);                                    // Album page
      LogMessage('No album selected');
// ANALYZE MUSIC PAGE
procedure AnalyzeMusicPage(Address: string);
   urlmusic, cover, Lenght, Pays: String;
   Autore, style, Commenti, str_min, campo_note: String;
   minu, minuti, ore, lgth_comm, save_lgth_comm, i: integer;
   j: Real;
   Page := UTF8decode(Page);
   if debug_album  then
      DumpPage(folder+'discogsPageDetail.txt', Page);                         // debug_album
   HTMLdecode(Page);
   if debug_album  then
      DumpPage(folder+'discogsPageDetailHTMLdecode.txt', Page);               // debug_album
   Readdress := '';
   Readdress := textbetween(Page, '<meta property="og:url" content="', '">');
   if length(Readdress) > 0 then
      Address := Readdress;
   if Pos('<div class="head">', Page) = 0 then                                          //inizio dati da estrarre
   Begin
      LogMessage('Pagina album errata - Error while reading album page');
   Normalizza_Page(Page);
//   Page := UTF8Decode(Page);                                              //fs2015-01-15
   albumok := True;
//dati generali
   initchar := '<div class="profile">';                    //io info generali
   endchar :=  '<div class="section_content">';            //inizio tracklist
   Value := TextBetween(Page, initchar, endchar);
   if debug_album  then
      DumpPage(folder+'discogsinfo_generali.txt', Value);
   initchar := '<div class="head">Label:</div>';
   endchar := '</div>';
   label := textbetween(value, initchar, endchar) + endchar;
   HtmlRemoveTags(label);
   label := StringReplace(label, CRLF, '');
   label := fulltrim(label);
//   label := StringReplace(label, '‎', '');
//   label := StringReplace(label, '–', '');
   label := StringReplace(label, '      ', ' ');
   SetField(fieldproducer, label);
   label := textbetween(Value, '<span itemprop="name" title="', '"');
   SetField(fieldoriginalTitle, label);                                       //artista in original title
   initchar := '<span itemprop="name">';
   label := textbetween(Value, initchar, endchar);
   SetField(fieldtranslatedTitle, label);
   initchar := '<div class="head">Format:</div>';                              //formato LP/Album/CD/ristampa ecc.
   label := textbetween(Value, initchar, endchar) + endchar;
   label := FormatText(label);
   label := stringReplace(label, CRLF, '');
   label := stringreplace (label, '  ', ' ');
   SetField(fieldvideoformat, label);                                            //formato
   label := textbetween(Value, '<div class="head">Country:</div>', endchar) + endchar;
   SetField(fieldcountry, label);                                             //paese
   label := textbetween(Value, '<div class="head">Released:</div>', endchar) + endchar;
   SetField(fieldyear, label);
//fs20150728  estrazione data della release
   nuovo_anno := getfield(fieldYear);   //fs20150728                                                //anno
   if length(nuovo_anno) = 0 then
      estrai_data_released;
//   end;
   label := textbetween(Value, '<div class="head">Genre:</div>', endchar) + endchar;
   style := textbetween(Value, '<div class="head">Style:</div>', endchar) + endchar;
   style := FormatText(style);
   if length(style) > 0 then
      label := label + ' (' + style + ')';
   SetField(fieldcategory, label);                                            //genere
//discogs tracklist
   initchar := 'id="tracklist" class="section tracklist" data-toggle="tracklist">';
   endchar :=  'class="section credits toggle_section    toggle_section_remember"';
   if length(Value) = 0 then
      endchar :=  'class="section notes toggle_section    toggle_section_remember"';         //inizio note;
      endchar :=  'class="section_content toggle_section_content">';         //inizio note;
      endchar :=  'section notes';         //inizio note;
   initchar := '<td class="tracklist_track_pos">';
   endchar :=  '</table>';
   Value := initchar + TextBetween(Value, initchar, endchar) + inizio_e_fine_traccia;
   if debug_album  then
      DumpPage(folder+'discogstracks.txt', Value);
   brani := '';
   estrazione_tracce;
//   value := stringReplace(brani, '–', '');
   value := stringreplace(brani, 'Composed By', ' - composed by');
   value := stringReplace(value, '*', '');
//   value := stringReplace(value, '&', '&');
//*** artists
   initchar := 'class="section credits';
   endchar :=  '<!-- /credits -->';
   initchar := '<div class="section_content toggle_section_content">';
   value := TextBetween(value, initchar, endchar);
   if debug_album  then
      DumpPage(folder+'discogscredits.txt', Value);
   brani := '';
   estrazione_credits;
   value := brani;                                                  //fs2015.01.21
   value := stringreplace(value, '            ', ' ');              //fs2015.01.21
   SetField(fieldActors, value);
//*** note
   initchar := 'class="section notes';
   endchar :=  'class="section m_versions';
   value := TextBetween(Page, initchar, endchar);
   value := FormatText(value);
   initchar := 'class="section notes toggle_section    toggle_section_remember"';         //inizio note
   endchar :=  '<!-- /notes -->';                                                         //fine note
   initchar := 'class="section_content toggle_section_content">';
   campo_note := value;
//*** barcode
   initchar := 'class="section barcodes toggle_section';         //inizio note
   endchar :=  '<!-- /barcodes -->';                                                         //fine note
   initchar := '<ul class="list_no_style">';
   endchar :=  '</ul>';
//   HTMLRemoveTags(value);
   value := stringReplace(value, CRLFspace, CRLF);
   if (value = 'Barcode:') or (value = 'barcode:') then
      value := '';
   commenti := '';
   if length(campo_note) > 0 then
        commenti := campo_note;
        if length(value) > 0 then
           commenti := commenti + CRLF + value;
           commenti := value;
//           end;
//      end;
   if length(data_rilascio) > 0 then
        commenti := 'Released on ' + data_rilascio + CRLF + commenti;
   SetField(fieldComments, commenti);
   data_rilascio := '';
//*** cover
   cover := TextBetween(Page, 'data-images=', '"full"');
   initchar := '"http:';
   endchar := '"';
   cover := initchar + TextBetween(cover, initchar, endchar);
//   cover := discogsUrl + cover;
   if CanSetPicture then
      GetPicture(cover);
Procedure estrazione_tracce;
    lgth_track: integer;
Begin
//    normalizza_page(Value);                       //fs2015.01.15
    initchar := inizio_e_fine_traccia;
    endchar  := inizio_e_fine_traccia;
    lungo := (Length(initchar) + length(endchar));
    Dati_traccia  := initchar + TextBetween(Value, initchar, endchar) + endchar;
    while Length(Dati_traccia) > Lungo do           //esegui se trovato qualcosa
       datitrack := '';
       track := '';
       endchar  := '</td>';
       datitrack := textbetween(dati_traccia, initchar, endchar) + ' ';           //n.d'ordine
       lgth_track := length(datitrack);
       if lgth_track = 2 then                               //num.traccia <10
          datitrack := '0' + datitrack + ' ';
       initchar := '<td class="tracklist_track_artists">';
       endchar  := '</td>';
       track := textbetween(dati_traccia, initchar, endchar);            //artista in antologie
       HTMLRemoveTags(track);
       if length(track) > 0 then
          datitrack := datitrack + '    ' + track + '     - ';
       initchar := '<span class="tracklist_track_title" itemprop="name">';
       track := textbetween(dati_traccia, initchar, endchar);            //titolo brano
       datitrack := datitrack + track;
       initchar := '<blockquote>';
       endchar  := '</blockquote>';
       track := stringReplace(track, '<span class="tracklist_extra_artist_span">', '<span class="tracklist_extra_artist_span">   ');
          datitrack := datitrack + '     (' + track + ')';
       initchar := 'class="tracklist_track_duration">';
       endchar  := '</td>';
       track := textbetween(dati_traccia, initchar, endchar);            //durata brano
       track := StringReplace(track, CRLF, '');
       track := FullTrim(track);
// dati del brano raccolti in datitrack
       datitrack := stringReplace(datitrack, '( ', '(');
       datitrack := stringReplace(datitrack, 'ritten-', 'ritten ');
       datitrack := stringReplace(datitrack, '–', '');
       datitrack := stringReplace(datitrack, '*', '');
       if length(datitrack) > 3 then
          brani := brani + datitrack + CRLF;                             //fs 2014.11.15
// reimposto l'area su cui loopare
       delete(Value, 1, length(Dati_traccia) - length(inizio_e_fine_traccia));
       dati_traccia := initchar + TextBetween (Value, initchar, endchar) + endchar;     //dati_album contiene i dati dell'album
//fs ********************* fine estrazione tracce *****************************************
Procedure estrazione_credits;
    oldtrack: string;
Begin
    initchar := inizio_credits;
    endchar  := fine_credits;
    oldtrack := '';
       datitrack := '';
       track := '';
       initchar := '<span class="role">';
       datitrack := textbetween(dati_traccia, initchar, endchar) + ' ';         //ruolo
       initchar := 'class="rollover_link">';
       endchar  := '</li>';
       if length(track) = 0 then
          initchar := '</span>';
       track := FormatText(track);
       datitrack := datitrack + ': ' + track;                                   //nomi
       datitrack := stringReplace(datitrack, '*', '');         //fs2015.01.21
       if track <> oldtrack then
       oldtrack := track;
       delete(Value, 1, length(Dati_traccia) - length(inizio_credits));
//fs ********************* fine nuova estrazione credits *****************************************
Procedure Normalizza_page(Pagina: string);    // elimina i crlf, trasforma delimiters maiuscoli in minuscoli
  pagina := RegExprSetReplace('<([^>]+)>', pagina, '<\L\1>', true);
  CharAbNormal := crlf;
  CharNormal := ' ';
  pagina := StringReplace(pagina, CharAbNormal, CharNormal);
  CharAbNormal := '<B';
  CharNormal := '<b';
  CharAbNormal := '</B';
  CharNormal := '</b';
  pagina := StringReplace(Value, CharAbNormal, CharNormal);
  CharAbNormal := '<FONT';
  CharNormal := '<font';
  CharAbNormal := '</FONT';
  CharNormal := '</font';
  CharAbNormal := '<TR';
  CharNormal := '<tr';
  CharAbNormal := '</TR';
  CharNormal := '</tr';
  CharAbNormal := '<TD';
  CharNormal := '<td';
  CharAbNormal := '</TD';
  CharNormal := '</td';
  CharAbNormal := '<DIV';
  CharNormal := '<div';
  CharAbNormal := '</DIV';
  CharNormal := '</div';
   if BatchMode > 0 then
      ShowWarning(m);
   batchlog.Add(m);
   batchlog.SaveToFile(batchlogfic);
// process batch mode
procedure discogsBatch;
   AlbumName := GetField(fieldUrl);                      // if no url or another site then ignore
   if (AlbumName <> '') and (Pos(AllAlbumUrl, AlbumName) > 0) then
      AnalyzeMusicPage(AlbumName)
      LogMessage('ignored url="'+AlbumName+'"');
procedure estrai_data_released;
//   ShowMessage('data di rilascio ' + nuovo_anno);
   label := StringReplace(label, ' ', '/');
   data_rilascio := label;
   mese_anno := Textafter(data_rilascio, '/');
   solo_anno := Textafter(mese_anno, '/');
//   if length(campo_note) > 0 then
//      begin
//        commenti := campo_note;
//        if length(value) > 0 then
//           begin
//           commenti := commenti + CRLF + value;
//           end
//        end
//        else
//           commenti := value;
   if length(solo_anno) > 0 then
          setfield(fieldyear, solo_anno);
// process normal mode
procedure discogsNorm;
   albumok := False;
   AlbumName := GetField(fieldTranslatedTitle);           // get album name
   ArtistName := getField(fieldOriginalTitle);           // get artist
    if not Input('discogs - ' + Value, 'Enter the name of the album :' + crlf, AlbumName) or (AlbumName = '') then exit;
       formato := getfield(fieldmediatype);
       if pos(formato, 'cd') > 0 then
          formato:= 'CD';
       artista := getfield(fieldOriginalTitle);
       GetList;
    until albumok;
//  start here
   if abort = 'o' then exit;                                   // batch mode aborted
   if firstcall <> 'done' then
   begin                                                      // 1st call: init parameters
      firstcall := 'done';
      if not CheckVersion(4,2,0) then
         ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 4.2.0)');
         abort := 'o';
      if BatchMode > 0 then                                  // batch mode: confirm the choice
         batchlog := TStringList.Create;                     // init batch log
         batchlog.Add('starting batch mode');
         batchlog.Add(StringOfChar('*',80));
// confirmation message
         confbatch := TStringList.Create;
         confbatch.Add('You have selected the batch mode:');
         confbatch.Add('Did you save your database?');
         confbatch.Add('*** Address to extract must be supplied in Field Url ***');
         confbatch.Add('');
         confbatch.Add('At the end of treatement:');
         confbatch.Add('- look at the file ' + batchlogfic + ' for errors/infos');
         confbatch.Add('- the albums found will be checked, the others not (for the selection)');
         confbatch.Add(' (see: Tools/Preferences/Movie list/checkboxes)');
         confbatch.Add('');
         confbatch.Add('confirm your choice');
         if not ShowWarning(confbatch.Text) then
           AddToLog('batch mode aborted');                   // batch mode not confirmed = abort
            abort := 'o';
// let's go
   if BatchMode = 0 then
      discogsNorm
      discogsBatch;
xenesys
Post by xenesys »
So.... for this new script I found :
1 - with search "symphony x underworld"
result : works great. List in order with all release in the high of the list.
I use this edition : http://www.discogs.com/Symphony-X-Under ... se/7269612
Release date is OK (full date and year).
2 - with search "symphony x"
result : no change. Answer incomplete and no order - the symphony x 's album are scattered.
The discogs search engine is bad... very bad....
3 - on the web site when I try this :
with "symphony x + heavy metal" >> - by the magic power I have all albums in the first 2 pages.
with "symphony x + prog Rock" >> OK - All albums in the list in the first 2 pages.
but, with the script, the album "underworld" is not in the list because he is in the second page on the web site.
4 - when I choose a album card and launch the script (Script : "normal" mode), it is searching with only the "translated title".
the "original title" field is not use so the script search with only "underworld" (too much results....) and not with "Symphony X underworld" (see N°1).
The results with this 2 possibilities are not the same. using the 2 fields is usefull than only one.
Can it be possible to force the search, in normal mode, with this two fields (group + album) ?
Conclusion of 3 + 4 : So this could be a solution : when we launch the script for an album card, the script could use :
"translated title" + "original title" (both in the popup of searching)
+ "style " (Heavy Metal, Prog Rock) (like the media type - no in the popupn / no selection / you select only the data in the field)
5 - why the media type is used in the searching ?
6- batch mode = ok ras.
:grinking:
Now I think we can say script works well and all problems "left" come from discogs search engine....
:??: :ha: :angry:
:??: :angry: :p
:ha: :??: :angry:
:ha: :angry: :??:
:angry: :ha: :??:
:angry: :??: :ha:
:hihi:
xenesys
Post by xenesys »
seriously ? the script can't be improved ?
:cry: :cry: :cry: :cry: :cry:
we can thank the discogs search engine..... :badidea: :angry:
you can't do the " "translated title" + "original title" " search ?
This would give the right album directly (exactly all editions of the right album).
xenesys wrote:seriously ? the script can't be improved ?
Your gentle kind of crying took my heart... in a few day....
:wink:
xenesys
Post by xenesys »
:lol: :hihi: :grinking:
I think I will cry all time now if I get what I want ^^
I'm very patient. so take your time.
thanks again ;)
xenesys wrote::lol: :hihi: :grinking:
thanks again ;)
done!
your tests are very appreciated.... still few minutes....
:hihi:
Updated with version 1.4.2!
