[UPD] discogs.com script - version 1.4.0
U P D A T E D  with vers. 1.4.1
xenesys
Post by xenesys »
I will do you a feedback when I will be in holiday (soon!!!)
xenesys
Post by xenesys »
I'm doing some tests (in mode normal) with this script and :
1 / with the search "symphony x underworld"
-> the result = a lot of album and the "symphony x underworld".
But the order of the list is a little problem - the "symphony x underworld" album is not in the high of the list (1st place).
-> the others results don't have a word of "symphony x underworld" in their titles. I found "symphony" or "underworld" in the web site page with "ctrl+F"
So : can we separate the 2 results ? section 1 : text in the title of the album / section 2 : text only in the web site page.
2 / with the search "symphony x 2015"
-> the script found "no result" :/
3 / with the search "symphony x"
-> a lot of result but again no order. The albums of the group "Symphony x" are not in the high of the list. They also are scattered in the list.
-> some of result have no word in the title but in the web site page I found the word "symphony".
4 / The date of the release is not imported because the date is "24 Jul 2015" not only "2015" like some others albums.
I try with this link :
http://www.discogs.com/Symphony-X-Under ... se/7269612
Can it be possible to keep the full date "24 Jul 2015" somewhere and the year in the year field in AmC ?
I will try to do others tests again.
And thanks again for this script ;)
xenesys wrote: 1 / with the search "symphony x underworld"
corrected; will be added in next update
xenesys wrote: So : can we separate the 2 results ? section 1 : text in the title of the album / section 2 : text only in the web site page.
impossible
xenesys wrote: 2 / with the search "symphony x 2015"
Album title "symphony x 2015" not present in discogs. Discogs doesn't search in release date.
xenesys wrote: 3 / with the search "symphony x"
xenesys wrote: 4 / Can it be possible to keep the full date "24 Jul 2015" somewhere and the year in the year field in AmC ?
I'll work on.
Continue with your tests, please.
