1: You can customize a dropdown-menu that you don´t use.
For example I made movie-groups like Star Wars, Godfather, James Bond.
Then you can group your movies dropdown-menu.
2: You can paste the path+filename in the URL-field,
and then hit the button to launch the movie.
(As long as it's on your harddrive.)
But how can I launch a movie concisting of two files?
Suggestions, anyone?
Tip: Customize dropdown-menu + launch file with URL-field...
stamla
For (1) there are several options about that in Tools -> Preferences -> Drop-down lists
For (2), I answered here: viewtopic.php?t=615
