Merge old and new catalog
Lio
Post by Lio »
Hi everybody!
I have to join two catalogs (amc files): the first with 2000 movies cataloged until 2007, the second has another 3000 since 2007 until today.
How can I merge together the two files into one with a numbering starting from 1 to the latest films.
Currently, both amc files start from the number 1.
I need to create a single file from the oldest movie to the newest one.
Help me please?
Thank You.
So you want to keep the old ones starting at 1, and change the numbers of the new ones, to be added at the end of the old ones?
Open the old catalog (or a copy of it) and go to File -> Import to import the new one into the old one.
If the option "Allow duplicate numbers" is not checked, it will re-number all the movies imported from the new one.
