I don't suppose there is a way to incorporate or view the exported data from this program.
I have it running excellent on my online domain. But, more and more are wanting to access the site using there mobile devices.
The exported XML file which contains all the data, and also all the images in the folder corresponding to each library ID.
Ideally a mobile program which can use the online xml file to view all the entries.
Thanks anyone who can provide any information.
AJW
Android Mobile Version
ajwconsult
Appreciate the reply. Is that the "Pocket AMC" you are referring to. As that is for a local file only.antp wrote:There is a reader for Android in the "Mods" section of the forum.
Alternatively, the database can be exported using a mobile-friendly HTML template, or using a PHP site also generating a mobile-friendly version, but I do not know if one exists.
I was looking at something like that, instead reading the data from online.
Can you please provide link or location of the Mobile Friendly HTML File template and I will have a look at that as well
Will that HTML one have the script we added a good while ago to enable ordering items.
Thanks, AJW
As myself don't have an Android device, I just saw that an app existed without checking exactly how it worked.
For the HTML template, as I said, I don't know if such template exists.
It probably wouldn't be very difficult to make.
I just use my own template, not optimized for mobile, but for the few times I need to access my list from my phone, I never felt the need of more.
windows10times
Not Able to Watch in Android Mobile
Looking for a fix. I am trying to watch on android mobile version 6.0 marshmallow. But not able to do so. What should i do now.?.. Help me out please.
dixitarjun
Re: Android Mobile Version
Pocket AMC Reader was working just fine on my Note 8 earlier running Android 7.0 however as I have updated to Android 8.0 whenever now I will open the app it only loads a blank white screen on the start up and after a while simply crashes itself. Any idea how do I fix it?
Update: Simply on uninstall and re-install the app working fine again
Dixit Arjun
showbox.onl/ mobdro.one/ dltutuapp.com/
Dixit Arjun
