help with pictures (xml-->amc)
cruentu
Post by cruentu »
so i got y re fine program, everything was ok.
than i saved it als .xml saw that all the pics where located in same dir, no problem, i kept updating my file, but it was my .xml file
after that i saved this xml file over my original .amc
--> all the pics are stored in a that dir, not in the .amc, whenever i move the file i have to drag all the pics
is there a solution, so i can import all these pics into the amc
ps all the names are still movie_1.jpg, ...._2.jpg, ....
thanxs
ps. if this problem is already solved somewhere in this forum i m sorry, but i've read most of it and didn't find it.
I made a small tool to correct this problem :
http://www.antp.be/index.php?l=uk&z=5&c=3&s=5
"AMC Image Import", in the middle of the page ;)
cruentu
thanxs
Post by cruentu »
you ve saved my day ;) :grinking:
